olds 350R Intake and Carb questions
Hello everyone here I have tons of questions if anyone actually has the time. So I have a 3711 edelbrock intake with a 1406 carb, ok I see that I need the spacer to clear egr valve. My problem is how to actually hook throttle cable to carb and do I need a new bracket, because this one dosent seem to work thanks any help
Remove it unless needed for your local emissions laws. You will probably still need a spacer to clear the EGR block off plate, I did with a Holley. Can always use a generic bracket and maybe cable too.
It's the original 350 block the car was built with. The intake manifold came from a later 75 Cutlass. The stock 2 bbl intake is in the shed with it's 2GC carb. The 75 intake was used because at the time it's what I had.
re: Blue rocket. The 455 was blue from 1970-1976. Prior to 70 it was red. After 1976 there was no rocket 455. The biggest engine in 77 was the 403. For 1970 - 1976 the Olds 350 was gold.
svnt442
July 17th, 2011 04:43 PM
