Olds 350 rebuild price
Edelbrock makes a variety of intake manifolds and there are many companies that offer headers - Hooker, Heddman, etc.
Intake manifolds:
https://www.summitracing.com/search/...-size/5-7l-350
Headers:
https://www.summitracing.com/search/.../oldsmobile-v8
Intake manifolds:
Headers:
[QUOTE=RocketRonnie;999017]How much was it for you to rebuild your olds 350?
Any tips.
I paid $1800.00 for a stock rebuild here in Canada back in 2008. I then added the Edelbrock 2711 intake, Edelbrock 600 CFM carb, hedman shorty headers, Miloden aluminum water pump and a few other things.
I didn't realise at the time, once you do the heads and don't mill them, you will loose compression due to the thicker head gaskets.
I wasn't a member here at the time I had mine rebuilt, if I had been a part of this awesome group of guys, I would have went about things differently and spend more $$$.
Be sure to ask these guys many questions so you can get the build you want.
Here is a picture of my 1976 350 wearing #8 heads.
I hope this helps
Eric
Any tips.
I hope this helps
Eric
I spent 3500 +/- but it used alot of swap meet parts / used / and hand me downs.
Runs 12.40's on pump gas.
10 to 1 compression speed pro flat tops (swap meep scores)
lunati voodoo cam 522/539 lift 233/241 duration @ .050 lift
Prw roller rockers 1.6 ford units
Pro gear timing chain
#6 heads done by rocket racing just bowl work 2.07 in. 1.63 ex.
full length headers ,x pipe
34 degrees of timing on 93 octane
edelbrock performer rpm intake
holley 750 cfm double pumper box stock
proform hei dist
Th350 built by me
And yes it really is that plain and basic. Nothing special just got it dialed in pretty good. Most people would spend about 6k on an engine like that i have that in the engine trans and rear end . The key to keeping the price down is doing it all yourself.
proform hei dist
Th350 built by me
I was selling that combo . But to be honest im not done chipping at that tree trunk. I plan on making the car faster with the same engine lol. I was selling this engine for 2500 but i had no real serious takers. The fact is i was selling this engine at a price you could break even., even if you needed machining but i had no real serious takers so it will continue to be in service until the car is painted and i have money to wrap up the next engine which is 90 percent done.
My " next " engine will be another 355 olds built along the same lines but i got some really good hand me downs and its take over 5 years to build. But its 355 with lighter pistons , ported heads , solid lifter cam ,single plane intake , Just a better build all around should be well into the 11's in the 1/4 mile.
76olds - "a dollar a day"
small info about real olds powered post.
proform hei dist
Th350 built by me
proform hei dist
Th350 built by me
I prefer glasstek., VFN is junk imo. Car is getting glass hood , deck lid and lexan side glass. I had glasstek fenders and hood in the past. The doors have had the beams taken out and once i go to the lexan i will closer to shaving 45 lbs from each door. I really want to shave about 200 lbs which will put me about in the 12.20 e/t and then try a new converter and hopefully the new fuel pump will help and we can get a 12.0 11.99 from it before the new engine. If money allows im doing glass bumpers too.
here is a link to the thread on my current doings. https://classicoldsmobile.com/forums...-part-2-a.html
absolutely with that idea.
Cost depends on what you want to do. I got close to $4000 in mine still need headers and exhaust. Edelbrock performer rpm heads, Scorpion rockers, Comp cam and lifters, Liberty timing set, Edelbrock performer intake, Quick Fuel 650 carb, Carter P4600hp fuel pump, Champion aluminum radiator, and of course all the new tune up parts and water pump and other miscellaneous items.
nice detailing.
Cost depends on what you want to do. I got close to $4000 in mine still need headers and exhaust. Edelbrock performer rpm heads, Scorpion rockers, Comp cam and lifters, Liberty timing set, Edelbrock performer intake, Quick Fuel 650 carb, Carter P4600hp fuel pump, Champion aluminum radiator, and of course all the new tune up parts and water pump and other miscellaneous items. I like a detailed engine compartment .with good thought process the upkeep is really minimal guys usually just valve covers and timing cover plus air conditioner and alternator for me everything else is aluminum and stainless. I pop the hood after a good run for cooling and most do not believe something pretty can run well but that is my angle to shiny to be taken seriously with class.
Byron is my home track and its 60 mile drive directly west from my house so thats my usual spot but my good friend 67cutlassfreak is 10 min. from the grove and can usually get me in for near nothing ., also a 60 mile drive but its a long winded drive compared to the straight shot.
#31
i have a overdrive and you can get them used even old units from motion performance days. motion was a major player for chevy in the sixties just like nicky and yenko and also harrell out of Kansas city. hone o dives are around periodically but used gvod are more common .I can go on for days about things like this and that's the reason I like these cars history and function. I periodically run a lot more power and if a issue should rise unexpedectly it is good to be closer to home to control costs it can happen. I built my ride with heavy duty parts period so I have a extra once of protection but with looks and perforamce and looking factory stock and new.
#33
rlorman - impressive engine bay. I never was one for the shine but you shut me up for sure, you found a way to pull it off.
Jtb- if your having probs with the pics then you should do a post in "site related" in the forum.
Copercutlass - thats how I like my set up, classicly muscle-ishis.
pfergy600
October 18th, 2013 07:21 PM
