Olds 350 high compression timing
Old May 21, 2024 | 07:47 PM
deltsanddueces's Avatar
So I yanked the 350 out of my car and went thru it
I did a compression test and I got around 190-195 psi per cylinder and when I pulled the heads I found forged flat top .030 over pistons in it
there were no numbers on the cam so I’m still not sure what kind of cam is in there. One of the main reasons I pulled it out was because I was having problems w pinging before
under some advice I replaced the edelbrock I had w a Holley 850 street hp and replaced the stock distributor with a MSD. I bought the ready to run msd and have it hooked right to the msd coil
I put everything together and popped the distributor in and hooked up the vacuum advance and fired her on the stand and it ran pretty bad til I bumped the timing down and played w the carb a little but it still not running great
my question is what should the initial timing be or a ball park
I’m running 93 octane pump gas
Old May 21, 2024 | 08:16 PM
70sgeek's Avatar
'72 Cutlass ragtop
Others will likely respond but it may arguably depend at least in part on the cam specs -required initial timing may essentially need between 12-15 degrees depending on what your cam may like, and all in around 34-35 degrees.
as an example, I'm running a roller cam 350 that Mark Remmel built - his cam has mid-500 lift specs and it really likes 16 degrees initial / 34 degrees total timing. In my case, I'm running a Pertronix Ignitor II electronic distributor and I had to experiment with the limiters that it came with to achieve the above-stated timing specs.
Also, make absolute sure your distributor is aligned with the #1 cylinder - even a tooth off can screw with your timing.
Old May 21, 2024 | 08:51 PM
As noted above, the total advance should be around 32-36 degrees. The initial is total minus mechanical.
On a high compression engine, higher initial advance can cause slow cranking speed especially when the engine is hot.
You may need to adjust the mechanical advance to achieve around 32 total with the initial low enough for easy hot start cranking (likely around 8 to 12 degrees).
Old May 22, 2024 | 06:41 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
What octane do you have locally? Yeah be on the conservative side like 36 max and if using vacuum advance, limit it to a handful of degrees.
Old May 22, 2024 | 02:14 PM
93 is the highest we got around here
Old May 23, 2024 | 05:26 AM
Sorry missed that, 93 is what you need. Honestly the factory MSD curve should be good, not too aggressive and 21 total mechanical advance in by 4000 rpm. Set you base at 13 to 15, see what runs best. If it has vacuum advance, no more than 10 degrees. I prefer manifold vs ported but see what is likes.
Old May 23, 2024 | 07:10 AM
so ur saying leave the springs n bushings in the distributor alone?
Old May 24, 2024 | 05:20 AM
Yeah, give it a try as is. You don't really want more initial or a quicker curve in your case.
ram_ra7760
Jun 19, 2020 07:00 AM
Seff
Apr 12, 2018 09:43 PM
george landis
Dec 9, 2013 09:38 AM
costpenn
Feb 15, 2013 09:49 PM
Gbobby
Jul 8, 2009 03:57 PM
