Oiling roller lifters
Old August 22nd, 2015 | 11:53 AM
cdrod's Avatar
Rodney
How do the rollers on roller cam lifters get oiled? I've purchased retro-fit, hydraulic roller lifters from Erson (SL-541) and don't understand how they are lubricated.
Old August 22nd, 2015 | 04:18 PM
cutlassefi's Avatar
The same way the cam to lifter interface does on a flat tappet, from the lifter bores and splash.
Old June 9th, 2021 | 04:07 PM
70W-32's Avatar
If your car is an automatic transmission, then check the torque converter bolts for looseness. This can cause a knocking sound similat to a spun rod bearing. Also check your belt driven accessories to make sure your pulleys are tight.
Vega
July 25th, 2023 03:32 AM
MartinH
July 1st, 2022 05:30 AM
cwb442
December 25th, 2016 06:28 PM
cdrod
June 12th, 2013 06:31 AM
Redog
August 14th, 2008 07:56 PM
