Oil pump
Old Mar 22, 2019 | 06:56 PM
coppertopgmc's Avatar
Oil pump
any ideas on oil pumps m22f or m22fhv for my 350?
Old Mar 23, 2019 | 06:17 AM
cutlassefi's Avatar
Sure, pick one. With the lack of info you gave just flip a coin.
Could you be any more vague?
Old Mar 23, 2019 | 10:11 AM
Smile
Well excuse me for being vague the car is going to mainly be a street car but may once and a while play at the drag strip, I always hear about oil issues pumping to much oil to the top end of the motor. is this just a 455 problem? I won't be running any type of restrictors in the engine and the rpms woun't exceed 5500, just not that familiar with the Olds engines, always built sbc now switching to Oldsmobiles.
Old Mar 23, 2019 | 10:31 AM
cutlassefi's Avatar
Was that so difficult?😉
Any idea of your bearing clearances? Normally for a small block a standard pump is fine. However I typically put high volume pumps in most of my stuff because they make significantly more power than a stocker does
Hope this helps.
Old Mar 23, 2019 | 12:42 PM
This will not be a stocker, mild build 9.6-1 cam 224/230 .050 480/495 lift w31 valves, not sure on the beating clearance but I would say it will be more on the +side
Old Mar 23, 2019 | 04:37 PM
cutlassefi's Avatar
You could always use a std pump with the high pressure spring, I do that from time to time.
Old Mar 24, 2019 | 04:23 PM
I just did an oil pump R&R (completely stock 1971 350 sbo) w/ the MELLING M22F & HP spring. Unfortunately, I did not perform an oil pressure test before I did the R&R. I used my ATP 0-140 oil pressure tester gauge & performed the test x3 times. I have ridiculously high oil pressure.
55-60psi (cold), 30-33psi (running temp) - 10w30, 135-140psi compression (wet & dry) on all eight.
deadeyejedi
Apr 25, 2024 03:06 PM
My2nd 69 442
Jul 14, 2018 09:24 PM
71cutty
Jun 20, 2017 10:35 AM
Jolly Green
Jul 24, 2013 12:16 PM
Ausraven
Feb 10, 2012 05:06 PM
