Oil pressure take off
Old Sep 6, 2017 | 02:06 AM
skippy's Avatar
Trying to locate the oil pressure take off on my 65 Vista ( 330), want to plumb the oil pressure gauge up but struggling to find the take off. Anyone give me a clue where its located?? Thanks
Old Sep 6, 2017 | 03:45 AM
The location is the one with the brass T. This picture shows both an oil pressure switch and a mod to use a mechanical gauge. Also you will notice on the intake manifold that there is both an aftermarket mechanical temp sender and the stock temp switch.
Old Sep 6, 2017 | 05:11 AM
skippy's Avatar
Thanks for that, no wonder I couldnt find it at back of engine or by oil filter
Old Sep 6, 2017 | 05:40 AM
A picture is worth a thousand words. Eric, is that the engine in your 67?
Old Sep 6, 2017 | 07:15 AM
Ummmm, no, google is your friend.
Old Sep 6, 2017 | 08:49 AM
Oh, ok.
Old Sep 7, 2017 | 12:17 AM
skippy's Avatar
Looked last night and there is no visible hole or tapping on my engine in that location
Old Sep 7, 2017 | 03:47 AM
Which location would that be?
Old Sep 7, 2017 | 04:05 AM
skippy's Avatar
As per the photo you posted.
Old Sep 7, 2017 | 04:49 AM
Are talking about the extra temp sensor location? That would only be available on some aftermarket intake manifolds. The oil pressure sensor you asked about should be where it is in the picture.
Old Sep 7, 2017 | 05:15 AM
skippy's Avatar
No not the extra temp connection, I have NO oil pressure switch or port where yours is located.
Old Sep 7, 2017 | 05:26 AM
Can you provide a pic of your engine?
Old Sep 7, 2017 | 05:32 AM
skippy's Avatar
Will try to get one in the next few days
Old Sep 7, 2017 | 05:34 AM
Here's a picture of an Olds 330. I circled the oil pressure sender:
Old Sep 7, 2017 | 05:41 AM
Your engine should look like this, the oil sender is on the drivers side next to the casting number on the front of the engine:
Old Sep 7, 2017 | 05:54 AM
skippy's Avatar
Can't see it but my alternator sits that side so bit obscured, will have another good look, unless for some reason someone has filled the hole
Old Sep 7, 2017 | 06:09 AM
svnt442's Avatar
All 64-90 olds engines have the oil sender in that location. Chances are that it's either obscured, or someone has removed it and plugged the hole with a pipe plug.
I highly doubt it has been filled in with weld as that would require much more work than would be practical.
Old Sep 7, 2017 | 06:52 AM
skippy's Avatar
Will have a look at weekend.
Old Sep 8, 2017 | 02:01 AM
skippy's Avatar
Had a quick look last night and definately "something" filler looking where it should be, not gonna dig about till later in year when not using it just in case it goes a bit wrong
Old Sep 8, 2017 | 05:17 AM
If someone put JB weld in the oil pressure port hopefully you can break it apart and use a shop vac to clean it thoroughly. If it has a plug in it you should be able to remove it with the proper tool. Good luck. Let us know what's up.
Old Sep 8, 2017 | 05:59 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I think his motor is painted orange.
I have never seen one blocked but who knows what someone did in 50+ years.
Old Sep 8, 2017 | 06:10 AM
No, its black...
Old Sep 8, 2017 | 09:08 AM
Then you don't have an Olds motor. EVERY SINGLE Olds V8 block cast from 1964-1990 has the oil pressure port in the same place. It's there. Look again.
Old Sep 8, 2017 | 09:20 AM
skippy's Avatar
Will try to get a picture at the weekend
foreverolds
Dec 1, 2012 07:07 PM
oldspackrat
Jul 22, 2011 05:01 PM
1983oldsmobiledelta
Sep 29, 2010 11:36 AM
1k442
Apr 22, 2010 08:14 AM
