Oil leak help.
Old March 12th, 2021 | 04:02 PM
Redbud40's Avatar
Oil leak help.
72 CS 350 stock. Don’t have a lift available but thought someone might suggest a source from similar indications.
Leak on pavement is collecting slightly in front of oil filter. Maybe directly under front part or slightly ahead of filter.
checked tightness of filter it seems plenty tight. Thinking maybe the oil filter housing gasket , but no real idea. Sound familiar to anyone. Plan on taking to a guy with lift and thought I might suggest or steer him to possible source. Thanks.
Mike.
Old March 12th, 2021 | 04:05 PM
66SportCoupe's Avatar
Valve cover gaskets
Old March 12th, 2021 | 04:10 PM
Once on a lift it should be pretty obvious...
Old March 12th, 2021 | 04:33 PM
Purchase a small bottle of engine oil fluorescent dye at any local automotive store where you can also purchase a small black-light pen-light (both are going to run you $10-$15. Add the dye to your oil, run the engine and visualize location of the oil leak.
Old March 12th, 2021 | 06:35 PM
Redbud40's Avatar
Thanks. Armed with dye and light and will hit the mentioned areas to see if I can spot the leak.
Old March 13th, 2021 | 04:35 PM
Redbud40's Avatar
Going for the Pax Side valve cover. Seeing some smoke while engine running coming from gasket area. Plus looks wet underneath. Got it off but lower rear and forward bolts PIA. Any techniques or proper tool suggestion for the reinstall of these two bolts. Better to ask experts here than to go through the knuckle gymnastics I used to take them off Thanks.
Gary's 2 442-S
June 30th, 2020 10:05 PM
dc2x4drvr
June 6th, 2020 05:03 PM
RustyOlds
February 7th, 2017 12:35 PM
1001coins
April 23rd, 2014 07:11 PM
defiant1
August 26th, 2011 10:45 AM
