Oil gusher
Old Apr 29, 2012 | 04:21 PM
805cut's Avatar
Oil gusher
Last night i was on my way home from a night out with some friends.. I had the car moving pretty good down the freeway, when i started to smell burnt oil. So i pulled over and popped the hood to see the oil cap had came off and oil had came gushing out and got everywhere...
Im assumeing the caps not the right one cause it dosent seem to lock on. Ill just get a new cap but wondered of any if you have had this happen? haha sure was a mess
or could this be related to my low oil pressure issue some how
just seeing what you guys think
thanks!
Old Apr 29, 2012 | 04:26 PM
coppercutlass's Avatar
Chevy budget Olds powered
I had this happen a few times at the drag strip. My quick fix was to close the oil cap with a shop rag underneath it to lock it. I have since welded a baffle inside the tube to further prevent it.
Old Apr 29, 2012 | 05:47 PM
captjim's Avatar
There should not be that much crank case pressure. Are you running a PCV system?
Old Apr 29, 2012 | 05:56 PM
From my experience those old caps get worn out and dont close too good. On mine it shook loose from the engine vibration . If he had that much crank case pressure he would also knock off the breathers or pcv valve .
Old Apr 30, 2012 | 09:49 AM
805cut's Avatar
yeah i knew it had to be a bad cap cause that thing was way to loose, but neve seemed to fall off.. This was the first "real" trip down the freeway since ive had the car, if that oil didnt get everywhere it would have been a perfect ride home.
thanks for the response
Redog
Oct 20, 2015 03:29 PM
defiant1
Aug 26, 2011 09:45 AM
Railguy
Tech Editor's Desk
Jul 25, 2010 02:36 PM
86pontiac
Feb 17, 2010 11:24 AM
