Nylon part for 350 Points Distributor?
Old Oct 19, 2021 | 08:48 AM
jharsh's Avatar
Received a rebuild points distributor for my Rallye 350 from RockAuto and the circled part below was loose inside the box it came in. I have no idea where it goes or what it is for. Any ideas? Thanks
Old Oct 19, 2021 | 09:20 AM
Yellowstatue's Avatar
That piece goes under the weights for them to slide on. Will be a hole for that button to sit in. Remove spring and lift weight off and you will see the hole or button.
Old Oct 19, 2021 | 09:50 AM
edzolz's Avatar
There should be one under each weight. That is most likely a spare. The rebuilt distributor should have two already installed.
Old Oct 19, 2021 | 01:18 PM
jharsh's Avatar
Took the weights off two different distributors and they both look like the below. No holes for a nylon button but both had a pad that looks to be a light metal.
Old Oct 19, 2021 | 02:23 PM
No nylon buttons for you. Lube the round flat area for the weights to slide on and you are done.
Old Oct 19, 2021 | 03:55 PM
jharsh's Avatar
Old Oct 21, 2021 | 07:48 AM
shiftbyear's Avatar
You might check for the mechanical advance bushing also.
EngineErnie
Apr 3, 2020 04:49 AM
OldsAl
Jul 31, 2017 10:35 AM
Olds442redberet
Dec 18, 2016 07:19 PM
1973cutlass
Oct 12, 2010 12:27 PM
BerBer5985
Jun 21, 2009 01:26 AM
