Number 5 heads - replacement valves
Old Nov 9, 2018 | 03:35 PM
VinMichael's Avatar
Does anyone have a recommendation for a budget conscious set of valves for these heads? I will be running adjustable valve train.
I am open to oversized valves since the valve seats will be re-done. But want to keep the valve stems close to stock height.
Old Nov 9, 2018 | 10:57 PM
rad's Avatar
rad
competition products sells some stainless ones for about $10 apiece.
Old Nov 10, 2018 | 09:10 AM
67 Cutlass Freak's Avatar
I like SI valves. They are very consistent in stem sizing. I would recommend getting at least .100" taller than stock for better geometry. Plan on replacing your guides and having them sized accordingly at the same time.
Old Nov 10, 2018 | 11:28 AM
Inline's Avatar
I just recently bought a set of SI Valves, portflow series. Issues with varying stem diameter on valves were found, with stem diameter varying between the plate and valve tip, being "fattest" on middle. Fixed on own expense. Disappointed for the crap quality. Made in USA...
Old Nov 10, 2018 | 01:56 PM
cutlassefi's Avatar
Who told you they were made in the USA? They’re not. They're either made in Brazil, Argentina, China, or God knows where.
I’ve pretty much quit using their stuff, for those reasons alone. Try PEP out in Nevada. Truly USA made, much better quality..
Old Nov 10, 2018 | 10:06 PM
Inline's Avatar
Well, on their main-page theres a statement about made in USA. So i quess they did. But thanks for the tip, will keep that in mind.
Old Nov 11, 2018 | 04:58 AM
cutlassefi's Avatar
Gotcha. Maybe some of their other stuff is made in the USA but I know for a fact their valves aren’t.
Old Nov 11, 2018 | 06:09 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
http://www.supercarsunlimited.com/35...lve-d1180.aspx
http://www.supercarsunlimited.com/35...lve-d1189.aspx
Here you go from a reliable seller. Their prices are the same as the sealed power stuff from Summit. The 2"/1.625" W-31 valves with the bowls opened with a bowl hog cutter will improve performance.
Old Nov 11, 2018 | 07:31 AM
Inline's Avatar
Maybe reliable, but no mentions from who those valves are sourced. Id stick for Cutlassefi's recommendation, since personally i cant suggest SI valves at all.
Old Nov 11, 2018 | 07:50 PM
coppercutlass's Avatar
Chevy budget Olds powered
you could always keep an eye out and buy someone's lightly used stuff lol. By which I mean a set of heads that need little to no work.
Old Nov 12, 2018 | 05:33 AM
Mark what kind of price do the PEP valves run? They have an easy to read catalog and I found the 1.995 and 2.07 intake and 1.62 and 1.71 exhaust valves. I say 2.07" and 1.62" exhaust valves.
Old Nov 13, 2018 | 04:12 PM
BillK's Avatar
First of all, I doubt that PEP's valves are made in the USA. I might be wrong but call them and ask to be sure. Here is a quote from their web page:"We are a manufacturer and importer of American, Import, Heavy Duty and Hi-Performance cylinder head components for worldwide applications."
That being said....... for stock replacement valves I have been using Eloy valves from SBI for many years and have never had any type of failure. They are absolutely OEM quality in my opinion, maybe better. They are NOT made in the USA but I doubt you will find any stock type or mild performance valve that is.
In today's world if you are making a purchase decision based on where something is made there is a chance you will make the wrong decision.​
Old Nov 13, 2018 | 05:02 PM
cutlassefi's Avatar
The Olds valves are USA made, can’t speak for anything else.
And they’re normally about 10-20% more than others.
Old Nov 13, 2018 | 08:10 PM
Bernard Mondello's Avatar
PEP valves are definitely NOT Made In USA...
Bernard Mondello Racing Enterprises, Corona, California. 951-371-1432
Old Nov 14, 2018 | 04:43 AM
cutlassefi's Avatar
Hmmm, then I need to have another discussion with them as they were shipped to me in a box that clearly said “made in USA”. Thanks Bernard.
1970_442
Aug 11, 2018 07:50 AM
Fullsizelover
Jan 10, 2014 04:44 PM
oldsy
Aug 24, 2013 12:56 PM
Hawk1061
Apr 2, 2013 06:44 PM
MN71W30
Jan 7, 2011 10:36 AM
