New HEI burned hole in cap
71 cutlass 350, swapped from points to HEI. bought a remaned distributor from the rock.
New Ngks Gapped to .45
New Moroso blue max wires.
New cap, rotor, and coil.
Ground strap present in cap.
This is less than 40 miles, car didn't run too well as you might imagine.
any ideas?
any ideas?
Try closing the gap on the plugs to .035 to start. No need for that big a gap. That looks like a cheap carbon button also. The bronze colored ones will last longer. Frankly the parts look like cheap products. Hard to tell from the pics but are those aluminum contacts in the cap? Those rotor contacts are just held together with that black plastic piece which probably allowed the spring and contact to corrode between the two. Good stuff is riveted together. Upgrade to the good stuff and try again.
Seriously, the button overheating is a known issue. As said, get good quality parts and all should be well. My HEI has factory GM innards and has worked well since the 80s. You can get premium cap/rotor/etc from the NAPA/Echlin line or from the Blue Streak line.
joepenoso
Jun 4, 2014 01:56 PM
pgcolvin
Oct 19, 2010 10:32 AM
