new engine for my 56 olds 88
To my knowledge, there is nobody that sells remanufactured engines for you 56. There are rebuild kits available but you are going to have to find a machinist that know these old motors.
Yes it can. I'm just trying to determine the cost difference. I purchased the vehicle 7 years ago and the seller said that the engine had been rebuilt. Since that time, I've had to replace the cams and lifters twice. I've only driven the car about 3000 miles. I moved out of state and I took it to a different machine shop and the guy is telling me that he recommends another engine rebuild? Something is wrong and I'm not sure if I want to put anymore money in this engine.
Thanks........that's the key. Finding the right machinist. I purchased the car 7 years ago and the seller said that the engine had been rebuilt. I've replaced the cams and lifters twice and I've only driven the car 3000 miles. Something has to be wrong with the engine which is causing the cams and lifters to keep getting damaged.
Something is very wrong if you've gone through 2 cam sets. The other problem is the amount of metal that came of those parts that may have contaminated other rotating assys. A tear down. thorough cleaning, and inspection at this point is probably in order to determine what needs to be done to fix it.
AAM
Little b4 my time and I'm not sure, without looking it up in my books, what engine lineage there was with late 50's 88's; however I venture a guess 56-58 are similar.
Here are 3 links - the first are 56 blocks.
How serviceable they are? is questionable. The first and last look pretty complete; considering - they are in a harsh environment to say the least. I suppose for a cost they may be candidates for resurrection. Hope this may be of use to you or others.
http://www.montanatreasureisland.com...picture&id=377
http://www.montanatreasureisland.com...picture&id=619
http://www.montanatreasureisland.com...picture&id=444
I wonder if the cam bearings have slipped or were put in wrong. There is an oiling problem somewhere. What kind of oil pressure does it have? Does it smoke and use oil. The only place I know of that knows everything about these engines is Ross Racing. Tony is the second generation in the business and helped me out on my rocker arms. Here is their link: http://rossracingengines.com/
1962oldsguy
May 5th, 2013 06:53 PM
ah64pilot
September 19th, 2012 10:55 AM
ah64pilot
August 17th, 2012 02:36 PM
