New Distributor for 1970 cutlass 350, recomendations?
Old Jun 14, 2016 | 04:59 PM
sammicurr86's Avatar
Need to get a new distributor for the 70 Cutlass 350? What models/brands do you guys recommend? Want to increase performance and reliability. Thanks
Old Jun 14, 2016 | 05:44 PM
What's wrong with the old one?
Old Jun 14, 2016 | 11:09 PM
Unless your old distributor has some issues, a new one won't increase performance.
I had an original points distributor set up with quality points, cap, rotor, recurve kit, and an aftermarket performance coil. It worked well to 6000 RPM. I swapped to a GM HEI distributor with quality cap, rotor, module, recurve kit, and a performance aftermarket coil. There was no absolutely difference in performance between the two.
Old Jun 15, 2016 | 06:49 AM
edzolz's Avatar
If you truley have to replace yours, DO NOT BUY ONE OF THE CHINESE KNOCKOFFS, They do not fit the block and they wear out long before a good brand will. I would recommend a Pertronix, an MSD, Mallory, or any name brand. It might be more costly, but better value in the long run.
Old Jun 15, 2016 | 06:55 AM
88 Cutty Classic's Avatar
Dui dui dui dui dui dui davis unified ignition!!!
Old Jun 15, 2016 | 07:02 AM
76olds's Avatar
Hookers under Hood
X2, I'm happy with the DUI unit I purchased. A little expensive but good quality.
Eric
Old Jun 15, 2016 | 07:07 AM
70cutty's Avatar
Beer Connoisseur
MSD 8529. Very happy with it.
Old Jun 15, 2016 | 08:19 AM
droptopron's Avatar
delete
Again, what is wrong with the one you have & what is the specs on the engine?
Old Jun 15, 2016 | 09:42 AM
Octania's Avatar
"Want to increase performance and reliability"
This may not be the best path for that destination.
Old Jun 16, 2016 | 12:30 PM
quaddriver's Avatar
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
an hei install (good luck finding used ones) will fire plugs in oil and they dont break too often.
Otherwise I dont see the words 'cheap part' next to too many of the new alternatives out there today
Old Jun 16, 2016 | 02:56 PM
walkerkj's Avatar
HurstOlds79
I bought an Olds HEI on eBay for $42. No more pow pow pow thru the exhaust when I remove my foot from the pedal. Works great and has lasted many miles. much better than points.
Old Jun 16, 2016 | 06:19 PM
A 1979 Hurst Olds already had an HEI distributor when it left the factory.
... Unless you mean a different car than the one listed under your avatar.
Old Jun 23, 2016 | 08:19 AM
walkerkj's Avatar
HurstOlds79
You are correct. I replaced the factory HEI with another one. There was a noticeable increase in performance. More complete burn in combustion chamber and none or much less in exhaust.
Old Jun 23, 2016 | 09:05 AM
Aahhh, the butt dyno is strong in this one.
Old Jun 23, 2016 | 09:08 AM
... And the Olfactory Mixometer.
Old Jun 23, 2016 | 10:23 AM
76olds's Avatar
Hookers under Hood
[QUOTE=walkerkj;928672] No more pow pow pow.
Sounds like they took alot of guns off the streets in your neighbourhood.
63super88
Feb 19, 2014 03:04 PM
mike1976
Jun 26, 2013 03:46 PM
65Delta88
Sep 20, 2010 02:42 PM
PmL69
Paint
Jul 6, 2009 05:04 PM
craftsmen22
Jan 18, 2009 02:41 PM
