Neoprene rear main seal for 350
I know this is an old thread but great instructions for the installation of the neoprene rear main seal. I wanted to ask if there is currently one specifically for an 72 Olds 350 or if is still need to ask for the ford 460 seal? I have been unable to find one- i only see the rope one. Eric had told me that I can install the neoprene one with the crank loosened a bit.
ANY F_rd 292. They all used the same seal.
As noted in this thread:
Rear Main Seal -- BS6141 -- Small Block Neoprene Ford Type (Y-Block 239, 256, 272, 292)
Rear Main Seal -- BS13879 -- Small Block Neoprene AMC / Jeep Type (196, 199, 232, 258)
Great! Thanks for all the Info. I'll be tackling this next week so I'm going to buy this seal tomorrow and get this baby buttoned back up. I believe you guys pointed me to a thread of how to remove the rope and install the neoprene seal with the crank installed correct? Thanks again!
Chris
Chris
Chris
Chris
Just to make sure here are two links to 6141 and 13879. Just want to make sure they look right. The 6141 is actually listed as a small block olds 64-90.
http://m.ebay.com/itm/FelPro-BS6141-Rear-Main-Seal-Oldsmobile-Small-Block-307-330-350-403-1964-1990-/191656373571?hash=item2c9f9c2d43%3Ag%3A5aUAAOSwLVZ VxRT6&_trkparms=pageci%253A86878a74-542d-11e6-8c99-74dbd1806314%257Cparentrq%253A2dc23a431560a357c0fe 6d66fffc75cb%257Ciid%253A1 and
http://m.ebay.com/itm/Fel-Pro-BS-13879-Engine-Rear-Main-Bearing-Gasket-Set-Rear-Main-Seal-Set-/361320633518?hash=item54206354ae%3Ag%3ALl4AAOSwl8N VfSAt&_trkparms=pageci%253Ac10adc3e-542b-11e6-abac-74dbd1e0600d%257Cparentrq%253A2db69e4c1560a2abd3f8 bddefffc8466%257Ciid%253A1
Ok. My seals should be coming in the mail tomorrow. If I'm doing this with the crank in place do I have to remove the oil pump to "lift" the crank to remove and replace with the neoprene seal? Anyone have any pics of doing this with the crank in? Also I've seen discussion about having the seams of the upper and lower seal meet in the block instead of horizontally. Thoughts?
The oil pump is attached to the rear main bearing cap, so, yes, it has to come out.
And, Yes, you have to offset the seams of the seal slightly from the block's machined surface.
So i removed the oil pump and rear main cap, turned the engine rightside up again in hopes that the crank would drop enough for me to remove the rope seal and install the neoprene but the crank didn't Appear to move at all. Thoughts?
#31
I think you can get decent leverage and control by lifting at the flexplate flange and/or at the flexplate bolts.
It will be easier to work looking down at the engine than looking up at it.
#32
You can try to pound the rope seal in its groove, but be 110% careful not to hit anything in the process. Then grab the exposed end with a pliers and pull it out. Installation is similar, but I like to "jog" the seal ends so they don't line up 100% with the main cap parting line. Generously lube the crank contact area of the seal with engine oil.
#33
I had no problem pulling out the rope seal with long, fine needlenose pliers, with the crank in place.
I just reached in and started pulling, and it all came out after a few tries.
There is also a special barbed wire tool made for this.
You can practice "rotating" the neoprene seal into the groove on the main bearing side before you do it on the block side.
#34
So I loosened all the main caps. The bolts were loose but I could not loosen the caps with the gentle pressure I was applying with a large pry bar between the flex plate mounting piece and the engine stand. I'm wondering if i should jut replace replace the 1/2 on the main cap and leave the block seal? I'm not one to do things halfa** but I don't know if I'm going to really mess something up...
#35
Yeah - you kind of have to whack the caps with a hammer to get them off.
A plastic hammer or wooden mallet is recommended, but I haven't heard of anyone damaging anything with a few civilized taps from a ball pein.
#38
I should clarify that you tap the corners of the bearing caps from side to side, with diagonal blows that go in toward the center of the crank, and upward, away from the block.
You don't tap in a front-to-back axis.
70rocketpilot
August 4th, 2018 06:10 AM
