Need valves and guide and seal brand recomendation
I have a 1979 Delta 88 stock cheapy rebuild low compression smog era 350 engine with very worn valve guides per the irradic readings on my vacuum guage and smokey morning start ups and rough idle.., compression is good for all cylinders though.. 150ish
I plan to get the heads rebuilt.
What valves, valve guides and valve seals brand or brands for each item do you recommend?? not looking for cheap, looking for something that is good quality and durable.. Iron or Bronze???
Also, what machining would need to be done to install them?
Thanks,
Fred
Thanks,
Fred
