Need some help here
Old Feb 19, 2017 | 10:20 AM
garage goat2's Avatar
Need some help here
I'm trying to prime my 350 SBO with oil.Yet despite me rotating it two full turns. I fail to get oil to the some of the rocker arms.
I'm wondering is my drill dying ( not enough RPM) Or keep rotating the engine and priming it. I do have 7 of them spitting oil yet not all of them? I'm ready to just crank it over with no plugs and see what happens?
Any ideas are appreciated.
Old Feb 19, 2017 | 01:19 PM
Ttt
Old Feb 19, 2017 | 02:20 PM
It can take a while, sometimes up to 20-30 minutes. Are you using a good heavy duty drill, like 1/2" drive?
Old Feb 19, 2017 | 02:24 PM
442Harv's Avatar
How long did you spin the pump? I have never had much of a problem priming a Olds, but I have had trouble with BB Chevys. It took a long time one time to get oil to the top. I was really getting worried, and finally, got oil. I read on the Chevy, that it can be a trapped air in the system. Maybe this is what is happening to you? I would keep priming, and turning the crank often. What size drill are you using, and what speed?
Old Feb 19, 2017 | 03:43 PM
RetroRanger's Avatar
72 Olds CS
Make sure your drills in reverse so it spins the dist ccw
Old Feb 19, 2017 | 05:09 PM
It's a 3/8 drill running in reverse and I'm running it wide open.
Old Feb 19, 2017 | 08:11 PM
svnt442's Avatar
Rotate the crank 90° and continue priming. You have to get oil through all of the oil passages.
Old Feb 20, 2017 | 12:04 AM
Ozzie's Avatar
The stock lifters are quite restrictive at idle pressures; as Eric said 20-30 minutes to get to the rockers.
Old Feb 20, 2017 | 12:50 AM
slade69's Avatar
Priming the engine with oil seems to be a thing that varies from build to build. I did not even need a drill, just turning the oil pump by hand. In day 1 rotated the pump 20 min and got the oil to about half of the rockers. Next day again 20min and got the rest as well. If I had used a drill, I would be covered with oil and garage walls too
Old Feb 24, 2017 | 07:56 AM
News Flash, Lifters were bad, The metering plates have no holes or notches in them!
Old Feb 24, 2017 | 09:45 AM
That has happened in the past also. Weird it was half of them.
gus91326
Oct 28, 2015 08:55 PM
marxjunk
Sep 24, 2014 03:20 AM
71cutlasslover
Mar 23, 2010 11:33 AM
88Classic
Sep 28, 2008 08:28 AM
billy_bob76114
Dec 13, 2006 02:47 PM
