I need help identifying a motor in a car I’m going to buy and help would be great
the number I have found on the block is 8c119790 This is the number I could find
OK, that picture isn't jumping out at me. What kind of engine do you think it is? Or what does the seller say it is? Can you share with us an overall photo?
The seller is saying is a 57 but I’m trying to figure out if is a 303 or a 324 I believe is a 52 I found a number 2 stamp on the middle of the exhaust ports
OK, we need an overall photo of it. And the title needs to have that in it. There are some 1950's guru's here but they will likely need to see more. The casting numbers on the heads can help, valve cover type will also be an indicator.
Really not enough pictures but if the head number is a #2 it may be a 52 303. The only thing is most of the early heads 49- 52 generally weren't numbered, I've heard of exceptions on 52 just to confuse the issue. The valve covers are the right color for a mid fifties 52 and up to 56 but not a 57. Did you notice if the distributor had a window for points adjustment or not? If so it would be a 56 or later engine that is if nothing has been changed in the last 65 years or so. Someone should have the range on the engine number but I don't have that information here to check. Doubtful if this helped a lot but maybe someone else has a better idea.... Tedd
Whatever it is, sitting in that oldskool hotrod I DIG IT! Beats the life out of a bellybutton SBC, that engine is kool. Like Buick Nailhead or Dodge RedRam Hemi kool!😎
By chance is it still 6 volt or does it have a 6 volt starter still in it? That would also point to a 303. I would buy it no matter what size Old's engine it had, it's high in the cool factor..... Tedd
