mostly stock 350 update and repairs
Old Feb 21, 2017 | 01:32 PM
72delta88's Avatar
ok ive had my 72 delta 88 350 since september and have done the following mods
msd hei coversion , 4 barrel intake , holley 600 carb and just general upkeep my question is has any one tried the summit brand timing set mine finally jumped a tooth and its time to replace it and im changing cams and heads soon but im limited on funds will it last 4 to 6 months
Old Feb 21, 2017 | 01:45 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Unless you are going to something like aluminum heads you would be wasting money to get rid of the 7a heads you have now. Just take them and have them cleaned up and maybe new springs to go with your new cam.
Old Feb 21, 2017 | 01:58 PM
For timing sets you consider these instead:
https://www.summitracing.com/parts/c...ake/oldsmobile
Old Feb 21, 2017 | 02:12 PM
From the link above:
...................Timing Chain and Gear Set, Heavy Duty, Double Roller, Iron/Steel Sprockets, Buick, V8, Set
Use the one in the second link instead.
Old Feb 21, 2017 | 02:19 PM
Oops so much for the Summit site search. Yeah disregard that one.
Old Feb 21, 2017 | 02:59 PM
72delta88's Avatar
I had to order a waterpump also so I had to go the 27.95 t chain I only had 110 to fix both
I ordered the summit brand chain I didn't see the cloyes when I ordered last night
Old Feb 21, 2017 | 03:22 PM
72delta88's Avatar
do I need to line up the dots or 12 0 cloc 12 0 clock them
Old Feb 21, 2017 | 03:32 PM
I use 12 o clock for the bottom and 6 for the top sprocket.
Old Feb 21, 2017 | 04:15 PM
72delta88's Avatar
ive got it at 12 12 now
6 is tdc
dizzy is at 6
does this sound right
DewChugr
Aug 15, 2016 07:05 AM
Copperstate
Apr 13, 2016 01:59 PM
oldspackrat
Oct 2, 2013 03:51 AM
Doug69Cutlass
Aug 14, 2010 05:05 AM
dingusboy
Feb 1, 2009 02:28 PM
