Misfire help
Old Apr 26, 2021 | 07:29 PM
Reese Neis's Avatar
Misfire help
So I got an 81 cutlass with a 76 350 in it and it’s got a little miss so I did plugs wires a cap and rotor I tried adjusting the timing and adjusting the air fuel ratio and still nothing took care of it no matter what it still had just a little bit of a miss anyone have any ideas what to check next
Old Apr 26, 2021 | 08:46 PM
Sugar Bear's Avatar
Triple check the firing order. Set the ignition timing and then move the timing light pickup to each plug wire while watching the flash. If the flash interrupts consistent with the misfire, that cylinder has an ignition problem.
Good luck!!!
Old Apr 28, 2021 | 08:37 PM
Cutlass Fan's Avatar
Do a compression test.
Old Apr 29, 2021 | 08:17 AM
67OAI's Avatar
Old(s)GuysRule
When using the timing light was the timing mark steady or did it seem to bounce around some? If the timing mark was not steady, it generally indicates a worn timing set.
bstott
Nov 19, 2013 08:19 AM
Seff
Jul 4, 2013 02:29 PM
66cutlass
May 31, 2013 08:19 PM
oldsguybry
Jun 3, 2011 08:36 AM
zates
Feb 23, 2011 01:14 PM
