Minimum I need to run engine?
Hi Everyone! So I installed my 72 olds 350 but I did not install the trans yet. I wanted to get the engine running before I hooked up the trans in case I needed to pull the engine again. What is the minimum that I need to hook up to safely get the engine running and accurately identify any issues? Obviously I know I need to install the entire cooling system (without trans cooler lines hooked up). But how much electrical? And which vacuum lines? Brake booster??? what else? Thanks guys!
Thanks Joe and Eric. It is not rebuilt- same cam. Maybe a dumb question, but can I start/run it without having the ignition switch hooked up and the throttle cable hooked up?
Thanks!
Thanks!
Needed to run:
- Engine attached to something stable
(motor mounts, and supported in the rear, if necessary) - Cable from battery (-) to block
- Cable from battery (+) to starter
- Wire from coil to battery (+) terminal
(if going to run for a considerable period, run it through a Chryler ceramic ballast resistor) - Wire from solenoid S terminal to touch to battery (+) to crank engine
- Fuel pump connected to a fuel source
- Radiator connected to engine
- Heater hoses connected or plugged
- Cooling system filled with water
- Open vacuum ports plugged
Needed to run and actually hear anything:
- Exhaust pipes and mufflers connected
Good idea:
- Connect mechanical oil pressure and temperature gauges
I figured the converter was effectively the required flywheel mass. Thinking about it, as a general rule, the more cylinders the less flywheel mass required for smooth running. Don't forget I'm from where 4 cylinders is normal. ![Smile](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
Roger.
Roger.
shamusj
March 4th, 2016 06:48 AM
69Rocket350
February 28th, 2012 07:31 PM
