Lifting my 330
Old Jun 6, 2016 | 06:26 PM
Napoleon Solo's Avatar
I'm indecisive. Or am I..
Lifting my 330
I need to get my engine off my engine stand and onto my run - up stand. I bought one of those lifting plates that you bolt on to where the carb bolts up. Will that do the trick? What grade of bolt should I use? I'd rather not find out if the 330 bounces...
Old Jun 6, 2016 | 06:34 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I know a lot of guys use the carb plate but I could never trust it. Of course it makes sense that four 5/16 bolts would hold more than the two 3/8 bolts I screwed into the side of the heads many times and used.
Old Jun 6, 2016 | 06:41 PM
lemoldsnut's Avatar
I made a chain for lifting Olds motors. It has the two hooks from a tie down strap and it is the lift chain sold at most auto parts stores. These hooks fit into the factory lift strap at the front of the intake on the drivers side and I also use the hole in the block on just below the distributor and towards the passenger side. this lifts the engine nice and safely. Two good solid points.
Old Jun 6, 2016 | 07:32 PM
Four gr5 bolts and lock washers will be sufficient.
Old Jun 6, 2016 | 07:33 PM
Thanks guys!
Old Jun 7, 2016 | 05:11 AM
rcwjr's Avatar
Absolutely no problems using a lift plate with grade 8 5/16" bolts and washers lifting a 455 with all accessories and TH400 attached into and out of a pickup truck.
Old Jun 7, 2016 | 09:03 PM
Whew - that's good to hear. Going to do that on Saturday.
Old Jun 8, 2016 | 01:28 AM
Redog's Avatar
I too go the bolt route instead of the carb lifting plate route.
When I did mine, I just ran the bolts in the head where the brackets go, I used 4 bolts, one on each side of the head, worked great
Boilerz25
Mar 22, 2014 03:19 PM
delta_88_germany
May 16, 2013 04:15 AM
Harmon
Feb 16, 2011 04:40 PM
Wilson05
Feb 7, 2010 06:29 AM
Dan Wirth
Nov 11, 2009 12:55 PM
