intakes
Old March 27th, 2014, 10:07 AM
johnnyjaws's Avatar
intakes
did they make a aluminum intake for 1970 350s # on in take is I think 22504068 will this fit a 1970 olds 350 motor ?
johnnyjaws is offline
Old March 27th, 2014, 10:09 AM
Octania's Avatar
it will fit, sure
That's the EGR era aluminum intake.
Look for the A4 or A5 large ID on the RH side, aft of the water passage.
A5 has tiny ports for 260 or roller cam 307 use.
A4 has 350-suitable ports.
There is an INTAKES thread here with photos of almost all known units in captivity.
Octania is offline
Old March 27th, 2014, 10:12 AM
johnnyjaws's Avatar
it says A 4
johnnyjaws's Avatar
Old March 27th, 2014, 10:13 AM
johnnyjaws's Avatar
this will fit a 1970 olds 350??? is it a good one to have Im not using the egr can I just plug it
Old March 27th, 2014, 10:47 AM
455man's Avatar
It should fit a '70 350. you can plug the EGR which it looks like it has been. Is the motor stock? I dont think the A4 is known for a performance intake but it's lighter than cast iron. Probably be an equal swap.
455man is offline
Old March 27th, 2014, 12:27 PM
DoubleV's Avatar
Yeah it'll work. Not a high performance intake though.
What's up with the 2 round indentions in the secondaries? Never saw those before in an A4 intake.
DoubleV is offline
Old March 27th, 2014, 01:00 PM
Lars's Avatar
there casting nubs and stick out about 1/4 inch, notice theres no crosshatch in the port floor, i believe its a very early model, the later intakes have croshatch in the floor
Lars is offline
Old March 27th, 2014, 01:56 PM
DoubleV's Avatar
Yeah all the ones I've seen had the crosshatching too. I think I'm mistaken about the casting nubs. I have seen those on the other A4's but what must have through me off was it looked different due to the absence of the crosshatching.
DoubleV is offline
Old March 27th, 2014, 08:01 PM
edzolz's Avatar
If you are going to block the EGR, I would unscrew the EGR tubes from the primary tubes and plug them with hex socket fittings. Just removes some more restrictions.
edzolz is offline
Old March 28th, 2014, 06:45 AM
Just keep in mind that the only "performance advantage this intake has over the stock cast iron 4bbl intake is lower weight. The runners are the same.
joe_padavano is offline
Old March 28th, 2014, 08:14 AM
captjim's Avatar
Also, check the cooling passages on the 4 corners (can't see them in the pics) they can get pretty corroded on those older intakes.
captjim is offline
Old March 28th, 2014, 10:09 AM
By the way, to answer the original question (did they make a aluminum intake for 1970 350s), the answer is yes on the W-31, and expect to pay $1500 for a good used original.
joe_padavano
Tech Editor's Desk
November 5th, 2009 05:08 PM
72 Supreme
July 17th, 2008 03:42 PM
65 starfire
May 30th, 2008 06:51 AM
B.O.P. Connection
October 29th, 2004 11:34 PM
Quick Reply: intakes
