intake manifold swap - perf rpm or stock cast iron?
Hi: currently running an edelbrock performer rpm intake on my '71 350. i have the eddie perf rpm camshaft in there now and yes its way to large for the streetable and daily driver application i want that has lots of low end torque. i'm switching to a much milder duration camshaft next spring (either comp cams or lunati voodoo). should i keep that eddie rpm intake or go back to my stock, cast iron one? compression is 8.5:1, running hooker long tubes and flow master delta flow 50's. have the option of either an edelbrock 600 cfm carb or my stock Qjet, i believe its 750 cfm. i have not touched the stock heads but might pull them to clean them up a bit.
You can pick-up the power by just changing heads, and maybe advancing the cam.
You don't mention the rear gear - under 3 doesn't help a large cam, and a 2000 + torque convertor would help a bunch, too!!
What exactly would he change the heads to? He could mill the heads and raise Cr up a point where the cam would work better. I had that cam (214/224) in a 9 to 1 355 with mildly ported heads and ran 14.8s. Switched to a 210/216 Engle, ran 14.2, eventually 13.9.
gears are probably 2.7? or even as low as 2.5?, not really sure. yeah that came with those gears and heads was a waste of money, fell head first into that classic trap of "bigger is better". i've been doing my homework now and pretty sure i want to go with either comp or lunati's 256 duration, both of which are supposed to work with my stock converter. going to keep stock heads and gears. i just put a shift kit in and that got some of the low end performance back but only marginally. i'm learing of porting those heads, don;t want to remove any metal,just want to clean them up a bit. car is just used for daily driving or good runs out in the country, no racing at all. fuel economy went in the toilet when i put that edelbrock cam in.
I have posted this a bunch of times,
http://www.realoldspower.com/phpBB2/...=performer+rpm
That same 9 to 1 355 was MUCH more responsive with the Performer and just a tad quicker.
thanks for that article,captjim. good reading. i'll try my new cam with the rpm manifold first and if i get a chance might put the stock one back on just to see. reason i'm asking is i thought the rpm was made to function at high rpm it might negate the low end torque i'll be getting with my new cam choice. it looks cool though so i definitely want to keep it if i can.
Hey guys, just to update you. confirmed that the motor i have in my 71 is not original. it has #8 heads and the 73-6 intake. kind of bummed. Already got a line on some 7a heads, no idea what shape they're in. my new question, is there any performance difference between the 411880 intake and the ones originally put on a 71? still debating on whether to keep my RPM on or swap it out for the original seeing as i'm going with a milder cam and shooting for streetability and better mpg.
update and a question. got the 7a heads and have had them cleaned up and a bit of porting done. question - are they identifical and interchangeable, can they gone on either side of the engine or is there a difference and one must go one one side and the other on the other side. If so how can you tell them apart? Putting them on this weekend, the #8's have already been removed.
VintageCarDoc
February 7th, 2014 07:42 PM
