Intake heat crossover
Old Aug 2, 2015 | 06:49 PM
truckerlary's Avatar
If one wanted to block the passages in the manifold to keep the heat out of the manifold what would be a good way to do it?
Old Aug 2, 2015 | 07:40 PM
Octania's Avatar
Stainless steel shim stock at the intake gasket
filler material like zinc in the heads
Solid cast iron plugs which are hard to secure to not rattle
Old Aug 2, 2015 | 07:46 PM
Stainless shim stock won't burn thru?
Old Aug 3, 2015 | 01:01 PM
And for aluminum intakes, aluminum plates welded into the port openings.
Old Aug 17, 2015 | 08:29 AM
Mrgadget's Avatar
I had a stainless shim stock added to my small block 2 years ago, still working great.
Before I added it, we could see the aluminum manifold turning a brownish color, now no color change.
Frank
Old Aug 17, 2015 | 09:51 AM
Octania's Avatar
Nothing lasts forever. I have some 0.005" shim stock I used a long time ago but not my car so not sure how it lasted.
Anybody wish to try it and report back with results I can drop a couple pcs in the mail.
I would think 0.010-0.020 material used with a thick composition gasket would not interfere with sealing and SS in general is pretty tolerant of heat abuse.
odddoylerules
Mar 8, 2015 07:49 PM
Crockett 999
Dec 30, 2014 01:08 PM
m455sx
Nov 2, 2011 06:40 AM
nuttycutty
Dec 23, 2010 08:32 PM
bjtstarfire
Nov 13, 2008 02:04 PM
