Intake assembly question
Old Jan 16, 2011 | 04:11 PM
dannymoz71's Avatar
Stupid question, but I figured Id ask anyway. When you get an intake gasket set for the SBO you dont get the valley pan. Are you supposed to use the valley pan along with the regular style gaskets or just the valley pan. Thanks.
Old Jan 16, 2011 | 04:15 PM
svnt442's Avatar
Just the pan. You put sealant around the intake ports and RTV around the water ports.
And I've found it best to ditch the front and rear seals and just run a bead of RTV instead. It wont push out like the seals tend to.
Old Jan 16, 2011 | 04:17 PM
dannymoz71's Avatar
Thats what I was thinking. Just wanted to make sure. Thanks.
Old Jan 16, 2011 | 04:22 PM
Oldsmaniac's Avatar
You can get a complete metal intake gasket from Fel=Pro. There are cheaper ones that dont have the pan or Turkey Tray. I never had a problem using the front and back rubber seals along with a bead of black rtv on top of each.
stratoblues
Sep 1, 2014 06:52 AM
svnt442
Jul 17, 2011 04:43 PM
amphicar770
Jan 18, 2010 02:02 PM
amphicar770
Jan 16, 2010 06:44 PM
