Idle?
Old Jul 29, 2023 | 07:18 AM
rickbmac's Avatar
Idle?
Set timing 13°advanced at idle 800rpm with warm engine. Left engine running while getting ready to drive and test. Engine began to stumble and died. Hard start (had to open carb wide). Momentarily it ran well again.
Ran down road to test. Throttled well with no hesitation at rpm over 1200 or so. When slowing down and decreasing idle engine stumbles again. Also exhaust burns my eyes and a bit black.
???rich???
Old Jul 29, 2023 | 11:31 AM
Sounds like the carb is flooding. Check for proper float level, crud in the needle and seat, or a "waterlogged" (fuel-logged?) plastic float.
Old Jul 29, 2023 | 02:26 PM
rickbmac's Avatar
Adjusted the idle. Idles great now.
Sometimes just quits when taking off from a stop. Just like flicking a switch.
Restarts immediately, but only if I SHOVE the pedal to the floor.
I will check the floats next.
Old Jul 29, 2023 | 02:30 PM
Run to Rund's Avatar
I assume you removed the vacuum line to the distributor and capped the carb fitting when setting timing. If not, do so.
Old Jul 29, 2023 | 02:50 PM
rickbmac's Avatar
yes I did
Old Jul 30, 2023 | 03:06 PM
rickbmac's Avatar
Friend had me up the idle when shifted in drive from 550rpm to 750rpm. Took in to town and zero stalls. Hopefully it's all better there.
On to the next.
Thanks all for assistance.
VinMichael
Nov 10, 2025 01:33 PM
coppercutlass
Apr 15, 2018 07:25 AM
Nop
Apr 29, 2014 09:34 PM
Robert Zuijdam
Dec 18, 2013 12:29 AM
66ninetyeightls
Aug 23, 2010 12:24 AM
