Identifying what hp 330 engine i have
How can I tell what HP 330 engine I have in my 67 cutlass supreme. #381917 1 Oil filler tube (looks like a V could be W very hard to read. behind the distributor 337 letters look like CFD on the head - 1 (drivers side) T (5?)9195 (pass side) it has an after market intake and carb. that's about all I can see for numbers. it was just rebuilt and repainted before I bought the car. Thanks in advance for the help.
If the engine has been rebuilt then what HP it was issued as is irrelevant.
290 or 310 HP were the ratings I think... but again, if the pistons are different, the cam is different, the heads have been rebuilt/ altered... it's all different.
To address your enquiry, Look for the engine application code stamped into [not a raised casting ID] the front of the RH head, like
W100123L or similar
The prefix and letter suffix is all you really need. Run that past section 0 of the Chassis Service Manual. I remember L is for Low compression export engines.
The numbers next to the dist'r are the casting date, not relevant.
The 6-digit number and larger number near the oil fill tube indicate it's a 330, no surprise nor any additional information.
Should have a big #4 on the corner of the head- nice to know, but irrelevant to the HP level before or now. More or less.
The 330 is quite a fine small block.
photos?
ps
"A #4 head would indicate large valves. " = bullsnort
The 1967 factory service manual says nothing about any small blocks having any valve larger than another. They all used #4 castings in 1967. The Ram Rod or W31 voodoo did not start until 1968, with #5 castings... and there is no way to spot a RamRod/W31 larger valve unit from a run of the mill #5 or #6 casting w/o measuring valves, AFAIK.
W100123L or similar
photos?
ps
So the answer is, the factory rating is irrelevant, as the motor has been rebuilt (with who knows what pistons or cam) and has aftermarket intake and carb.
