I forgot
Alright, my cars been apart for quiet some time. Now that its time to put things back i wish i took more pictures haha. O well i got a assembly manual coming in the mail. Just trying to get all the little stuff out of the way gathering up parts. Old gal gose into the shop next week. FINALY!
No, you don't need to change the throttle cable...but you will need to modify the throttle bracket to clear the back of the carb. There are some little braces or something on the back of them that hit the bracket. You can either clearance the bracket or clearance the carb...I prefer the bracket over a newly purchased carb.
I have used 1" steel plate to make an adapter bracket that clears the carb and bolts in the factory location...then drill holes for the factory bracket in the adapter plate and bolt them together. Just an idea that has worked for me.
Like i said, just trying to take care of all this little stuff before the shop takes over and charges me for it
Thank you!
Right on brotha! Im out here in Ventura....no I have a 72 cutlass gray white vinyl top and white racing stripes just picked it up about a month ago, it's def gots some work to be put in.....I know which red one your talking about tho! I saw it at a gas station by my house the other day, that car looks sick!! It's the convertible right??
The cars running right now, everythings pretty much stock besides the 4bbl carb, I'm lookin to take it one step at a time...starting from the rear end switching gears up to posi 3.42 adding dual exhaust and headers then work my way towards the engine/tranny hopefully be able to lay some rubber down soon. It also needs body work. Are you lookin to do a stock rebuild or wake up the good ol 350?!
Hopefully i can get this b!tch running, we could meet up. You ever go to the camarillo car shows? Not sure if there still going but i want to start entering the car when its done.
