how mach mill the edelbrock head?
Hello.
How much is what must be lowered in the cylinder head edelbrock for a compression ratio of 10: 1 with a flat piston and a cylinder head gasket 4.125 x 0.027 for engine olds 355 or 350 + 030?
regards.
regards.
Another option is Bernard mondello and procomp heads: he cleans them up, puts good parts on them and he can set them up for a small block, for the price of bare edelbrocks.
Not just the cc's of the heads but the other variables like , head gasket thickness , and how far the pistons sit in the bore. There is no magical cut to get 10 to 1 compression its all part of an equation.
Hi.
It is madeĦĦĦ ... With a brushed 0.090 in the cylinder heads Edelbrock, is a combustion chamber of 64cc, so with thick head gasket 0.040 and cylinder rectified to 0.030 and pistons probe, resulting in a CR = 10.5: 1 ...
regards.
regards.
Milling .006 off of the head = 1 cc (this according to an accredited member)
4.087 bore/3.385 stroke/4.125 head gasket bore/ flat top piston/64cc head/0 deck/.040 gasket = 11:1 if my math is correct.
Probe Pistons have a -3cc relief. Probes set .025 in the hole (thats where my -5.8cc speed pros are and this is a recommended depth) should give you around 10:1
Joel
April 26th, 2017 01:37 PM
wmachine
August 1st, 2010 04:00 AM
