how mach mill the edelbrock head?
Old Jul 13, 2015 | 07:59 AM
pablocutlass's Avatar
Hello.
How much is what must be lowered in the cylinder head edelbrock for a compression ratio of 10: 1 with a flat piston and a cylinder head gasket 4.125 x 0.027 for engine olds 355 or 350 + 030?
regards.
Old Jul 13, 2015 | 03:06 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Around 70cc will put you close.
Old Jul 13, 2015 | 03:21 PM
But, how much mill?? 0.02 or 0.08... Someone grinding these heads, to increase the compression ratio?
Thanks and regards...
Old Jul 13, 2015 | 03:31 PM
70cutty's Avatar
Beer Connoisseur
Whoever is doing the machine work is gonna have to cc the heads first. There is no telling if they are 77cc or more. If your machinist can't figure that out, find another one.
Another option is Bernard mondello and procomp heads: he cleans them up, puts good parts on them and he can set them up for a small block, for the price of bare edelbrocks.
Old Jul 14, 2015 | 10:50 AM
coppercutlass's Avatar
Chevy budget Olds powered
Not just the cc's of the heads but the other variables like , head gasket thickness , and how far the pistons sit in the bore. There is no magical cut to get 10 to 1 compression its all part of an equation.
Old Jul 23, 2015 | 09:53 PM
Hi.
It is madeĦĦĦ ... With a brushed 0.090 in the cylinder heads Edelbrock, is a combustion chamber of 64cc, so with thick head gasket 0.040 and cylinder rectified to 0.030 and pistons probe, resulting in a CR = 10.5: 1 ...
regards.
Old Aug 10, 2015 | 01:39 PM
1BOSS83's Avatar
Hi.
regards.
How did you get Probe Pistons? I tried for half a year.
Milling .006 off of the head = 1 cc (this according to an accredited member)
4.087 bore/3.385 stroke/4.125 head gasket bore/ flat top piston/64cc head/0 deck/.040 gasket = 11:1 if my math is correct.
Probe Pistons have a -3cc relief. Probes set .025 in the hole (thats where my -5.8cc speed pros are and this is a recommended depth) should give you around 10:1
Joel
Apr 26, 2017 01:37 PM
Chumpy2112
Jul 16, 2013 06:37 PM
68SUPERCHARGED
Jun 19, 2013 11:01 AM
Erinyes
May 6, 2013 01:56 PM
