hooking up a sunpro oil gauge
I believe you will find a small fitting on the deck that the oil filler tube is in. It should be about 2.5" to the right of the filler as you are looking at it. I don't know what was in the hole from the factory as mine was already set up with a gauge when I picked it up. hope this helps
Reddog is correct. What you see when you look at the top of the engine just behind the water pump on the right side is the sending unit for the electric guage or light. after you remove it you will find a 1/4" threaded hole. buy a 1/4" brass nipple and a "T" fitting use thread sealer and install the electric sending unit in the top hole and the 1/4" brass fitting in the side hole and install the 1/4" line there
golds56
December 13th, 2011 06:53 PM
