hooking up a sunpro oil gauge
Old Sep 16, 2008 | 05:36 PM
JEREMY VANSANDT's Avatar
I dont kno where to hook up my mechanical oil pressure gauge where do i hook it up on the block this is for a 1976 cutlass salon with a 350
Old Sep 16, 2008 | 06:08 PM
csstrux's Avatar
I believe you will find a small fitting on the deck that the oil filler tube is in. It should be about 2.5" to the right of the filler as you are looking at it. I don't know what was in the hole from the factory as mine was already set up with a gauge when I picked it up. hope this helps
Old Sep 16, 2008 | 06:10 PM
csstrux's Avatar
I should specify, this is for the olds engine only. If the car has a sbc in it I'm not sure where the fitting would be.
Old Sep 16, 2008 | 06:45 PM
dan2286's Avatar
I am pretty sure there should be something there whether he had a gauge or not. If he doesnt have the gauge it should be an oil pressure switch to turn on the idiot light if pressure goes to low.
Old Sep 16, 2008 | 07:02 PM
1971olds350's Avatar
im guessing its right under the thermostat housing screwed on the block a little to the right. how much did it cost you
Old Sep 16, 2008 | 09:36 PM
Redog's Avatar
^^^ Yes, but you'll need an oil pressure sender socket to get the stock sender out, and "T" it
Old Sep 17, 2008 | 04:06 PM
citcapp's Avatar
Reddog is correct. What you see when you look at the top of the engine just behind the water pump on the right side is the sending unit for the electric guage or light. after you remove it you will find a 1/4" threaded hole. buy a 1/4" brass nipple and a "T" fitting use thread sealer and install the electric sending unit in the top hole and the 1/4" brass fitting in the side hole and install the 1/4" line there
Old Sep 19, 2008 | 04:08 PM
380 Racer's Avatar
Actually it's a 1/8" NPT threaded hole.
Old Sep 20, 2008 | 08:10 AM
citcapp's Avatar
On My 455 it is 1/4". Does not look like it was ever tapped out. Hmmmm.
tru-blue 442
Nov 21, 2014 07:21 PM
golds56
Dec 13, 2011 05:53 PM
clinton70
Feb 7, 2010 03:48 PM
silverriff
Apr 14, 2008 07:00 AM
