Holley Carb on Edelbrock Intake
I have a Edelbrock Performer intake on my 350 with a Edelbrock 600 CFM Electric Choke carb sitting on it. I am having some performance issues with the carb, and have a friend who has a brand new in the box Holley 600 CFM Electric Choke carb he will let me have REAL cheap. Will it bolt right on, or do I need some kind of adapter to make it work on the Edelbrock intake?
What other parts will I have to change, linkages fuel lines etc?
Thanks...
Thanks...
I just swapped a holley 650 dp in place of the edelbrock 1405 i had in there and holy crap throttle response was better and i havent tuned it yet. Im happy with it my previous experience with a holley style carb was horrible stick with the holley brand .
What kind of throttle cable linkage/brackets did you use?
d1
I fabricated my own from flat stock steel it goes from one of my valve cover studs to the dr. Side carb mount stud. I'll take a pic tommorow when I'm at the shop. It will work with both the edelbrock and the holley.
Thanks for taking the time to post the pic. Not sure what I am going to do yet, but your setup gives me another option.
thanks again
d1
Yeah I got tired of messing around with the cheap one from summit which i bent and welded so it would work. I made this because i didnt feel like spending the money on a new bracket., I had some flat stock and the piece that holds the cable so i made some bends and welded it all up.
svnt442
July 17th, 2011 04:43 PM
