Holley Carb on Edelbrock Intake
Old Mar 7, 2012 | 08:11 AM
OldsManNJ's Avatar
1971 Cutlass S
I have a Edelbrock Performer intake on my 350 with a Edelbrock 600 CFM Electric Choke carb sitting on it. I am having some performance issues with the carb, and have a friend who has a brand new in the box Holley 600 CFM Electric Choke carb he will let me have REAL cheap. Will it bolt right on, or do I need some kind of adapter to make it work on the Edelbrock intake?
What other parts will I have to change, linkages fuel lines etc?
Thanks...
Old Mar 7, 2012 | 11:20 AM
It should work!
Old Mar 7, 2012 | 04:01 PM
jag1886's Avatar
I am using a 80457 Holley 600 on my Edelbrock maniflod and it works great. I know a lot of people cuss Holley's but I have always used them and have great luck with them.
Old Mar 7, 2012 | 05:24 PM
coppercutlass's Avatar
Chevy budget Olds powered
I just swapped a holley 650 dp in place of the edelbrock 1405 i had in there and holy crap throttle response was better and i havent tuned it yet. Im happy with it my previous experience with a holley style carb was horrible stick with the holley brand .
Old Mar 7, 2012 | 06:15 PM
LoganMiller68's Avatar
I have Holley bolted on my Edelbrock manifold and it works great!
Old Mar 7, 2012 | 06:21 PM
defiant1's Avatar
What kind of throttle cable linkage/brackets did you use?
d1
Old Mar 7, 2012 | 06:28 PM
I fabricated my own from flat stock steel it goes from one of my valve cover studs to the dr. Side carb mount stud. I'll take a pic tommorow when I'm at the shop. It will work with both the edelbrock and the holley.
Old Mar 8, 2012 | 06:40 PM
@ defiant1 and others intrested this is the braket i made. I made this so i would get full throttle no matter what i had issue with my last bracket .
Old Mar 8, 2012 | 07:04 PM
defiant1's Avatar
Thanks for taking the time to post the pic. Not sure what I am going to do yet, but your setup gives me another option.
thanks again
d1
Old Mar 8, 2012 | 07:10 PM
Yeah I got tired of messing around with the cheap one from summit which i bent and welded so it would work. I made this because i didnt feel like spending the money on a new bracket., I had some flat stock and the piece that holds the cable so i made some bends and welded it all up.
Old May 23, 2012 | 07:39 AM
71 455's Avatar
ive got a holley on my edelbrock torker II manifold- works great (other than the carb puked on me )
Old May 23, 2012 | 08:20 AM
Which unfortunately has nothing to do with a Performer 350 intake from a clearance or performance standpoint.
5998DownUnder
Feb 10, 2014 09:17 PM
transam79
Sep 25, 2012 09:28 PM
transam79
Sep 25, 2012 06:50 PM
svnt442
Jul 17, 2011 04:43 PM
