hesitation at WOT
Old Dec 13, 2011 | 08:23 PM
Rob delta's Avatar
hesitation at WOT
I have an 83 307 with the ccc q-jet. The tps is new and adjusted correctly as is the mixture solenoid. The timing is set a little over 20 degrees. I have a very slight hesitation when accelerating from idle (gradually accelerating, not wot). It may not happen all the time and is not all that noticiable. My main issue is when i go to WOT from idle at a stop. The engine really stumbles then recovers and takes off. Also, when at a cruising speed if I go to WOT the engine doesn't stumble but there is definitely a hesitation before it takes off. I've checked the secondaries and they do open fully when holding the throttle open. I assume there will always be some delay on the secondaries opening when going to wot. but is it possible that the primary vacuum break is bleeding off vacuum to slowly and therefore preventing the secondary air doors to open quicker?? But I am also aware there is a way to adjust the tension on the secondary air door but before touching that is there anything else that can be causing this? Is the mixture becoming extremely lean for an instant and then recovering when the engine picks up speed?
Thanks to all in advance for your help
Old Dec 14, 2011 | 04:48 AM
CQR's Avatar
CQR
Sounds like just the opposite is happening. I would say that, by your description that the secondaries are opening too fast. Check your pull-offs for proper operation, but I'm gonna guess that you need to tighten up the wind-up on the secondary air horn. Your hesitation off idle sounds like a weak accelerator pump or misadjusted pump rod.
Old Dec 14, 2011 | 06:08 AM
X2 on accelerator pump
Old Dec 14, 2011 | 06:58 AM
Lady72nRob71's Avatar
Yes, check secondary air door spring tention first. Also check you vac hoses and carb bolts - could have a vac leak. Does the EGR valve plunger move freely? Easy stuff first.
Old Dec 14, 2011 | 07:46 AM
AZ455's Avatar
1974 DELTA 88
That's what I'm thinking also. It's somewhat difficult to set correctly, or it has been on mine anyway. I have the same problem. I currently have the tension set where the manual suggests, which made an improvement, but I think I need to tighten it up even more.
Old Dec 14, 2011 | 10:12 AM
Rickman48's Avatar
Only times I've had WOT problems, I've changed the bronze filter in the carb, and/or the fuel pump.
Make sure the fuel system is up to par, first!
Old Dec 14, 2011 | 10:46 AM
AZ455's Avatar
1974 DELTA 88
Bronze filter? Are you just talking about the small fuel filter in the fuel inlet of the carb?
The fuel pump is a good idea, I suspect mine is likely due to be replaced. Going to test soon. They're cheap and easy at least.
Old Dec 14, 2011 | 11:15 AM
Rickman48's Avatar
Yes, the older ones are bronze - newer - paper.
Just be carefull - easy to F. U.
Old Dec 14, 2011 | 10:32 PM
Rob delta's Avatar
Thanks for the responses. Today while driving I was able to test things out a little. First: from a stop at idle going to wot. It didn't really seem to stumble as i used to remember it doing a while back. I think the hesitation i did experience is due to the gearing in the rear and the 307 trying to overcome the weight of a delta 88 at a dead stop. But once it begins moving it takes off pretty well.
Second: Cruising at around 30-35mph then going to WOT. Again it didn't really bog the engine down, however there is a slight lag time til the secondaries open. I think it might be because the vacuum break takes a second or two to bleed off vacuum which then releases the secondary air vent This may be normal but I am not sure. Ok so the secondaries finally open, engine revs up and car takes off. Problem is i leave a cloud of smoke behind, seems to fade away after like 3-4 seconds. Now this smoke only seems to happen when i'm already cruising along then go to WOT. Is this because of a momentarily rich mixture? why does it only seem to happen when i'm already at a cruising speed?
Old Dec 14, 2011 | 10:38 PM
Rob delta's Avatar
The exhaust cloud doesn't happen from idle to WOT (or only very little). It's when already in motion and then going WOT that I leave the smoke behind
Old Dec 15, 2011 | 12:09 AM
Rickman48's Avatar
My '86 GP 2+2 [CCC]used to wear out the primary throttle shafts about every 60k miles.
Grab the linkage and move it around - if it's loose, you might consider having it re-bushed for a permanent fix. At the time, I'd get one from a yard, as they were plentiful with low miles.
You might also consider advancing the timing a bit, to compensate for stretch in the timing chain.
My water pump went out @ 68k, and I did a Cloyes for longevity. Both were still in it when I sold it @ 230k.
Old Dec 15, 2011 | 08:34 AM
Rob delta's Avatar
There doesn't seem to be much play trying to move the linkage around. I believe the timing was at 22 degrees last time i checked. Any ideas what can be causing the rich condition i explained in my last post?
Old Dec 15, 2011 | 08:38 AM
CQR's Avatar
CQR
Again having the secondaries opening too fast will give you your bog and smoke.
Old Dec 15, 2011 | 08:43 AM
Rickman48's Avatar
Any play is a vacuum leak - how many miles, and did you check the carb base gasket????????
Old Dec 15, 2011 | 08:56 AM
AZ455's Avatar
1974 DELTA 88
I can see the secondaries opening too fast causing a bog from a momentary lean condition, why the smoke?
Old Dec 15, 2011 | 09:29 AM
CQR's Avatar
CQR
The lower plates open the uppers open slowly and at the same time raise the metering rods for the secondaries. If they just flop open then the metering is a sudden rich condition. the motor cant take such a huge flush from the big secondaries.
Old Dec 15, 2011 | 12:20 PM
Rob delta's Avatar
That makes a lot of sense. When the air vent flops open to quickly, the first thing to come to mind would be a lean condition but considering it also lifts the metering rods, i have a rich condition for a few seconds til the engine recovers. I will try increasing the tension slightly and test it out. Service manual calls for 1/2 turn past zero tension. I have no idea what the current setting is, but it does have some tension but i guess it's not enough. How do i know if i went too far with tightening, will it again bog down?
Thanks for the help
Old Dec 15, 2011 | 12:24 PM
CQR's Avatar
CQR
Yes. I would rec. 1/4 turn adjustments at a time
1965cutlassragtop
Jul 1, 2012 02:00 PM
84oldsDelta88
May 12, 2011 06:52 AM
wolskara
Sep 14, 2010 09:42 PM
RAMBOW
Nov 29, 2009 02:30 AM
W30post
Nov 30, 2007 02:46 AM
