HELP! Top End Rebuild 78 Olds 350
Old October 19th, 2019, 06:58 PM
  #41
rktpwrdc10's Avatar
No I would leave them alone if they are ready to go. If they need the valves replaced I would consider it. No point in spending too much on factory heads nowadays with the cheap aluminum heads that are available now.
rktpwrdc10 is offline
Old October 21st, 2019, 05:56 AM
  #42
brownbomber77's Avatar
Originally Posted by Goodoldsreliable
Im located in southwestern ohio north of Cincinnati. Might be worth the trip to grab those #3 heads if the #5's don't work out
Didn't the "5" heads have a smaller compression chamber than the original 3A heads therefore the thickness of the gasket minus the smaller combustion chamber equals out the same? They do, I'm talking about #3 heads, NOT #3A, they came on 330s and have ~64cc combustion chambers
Also, your saying the head bolt holes need to be drilled as well, im assuming this would be done by a machine shop. Are the angles the same? I read something about some being 39° angles rather than 45°. ALL Oldsmobile V8 head bolts are square to the deck, you're thinking pushrod holes.
I thought the 5 heads (no "A", being from 68 or 69) would be a good match? Are there any options besides 3A that are a direct bolt on? I just was to upgrade while im at it but dont really have to funds do go have something machined. I have no idea how much and of that would cost. They are, I like to use the #3 and #4 heads from 330s on the later models to make up for the massive piston dish and thicker head gasket. You will, no matter what, have to have the head bolt holes (On 2, 3, 4, 5, 6, 7, 7A, 8 heads) drilled out to 17/32 on a mill drill that has a square table that can support a 53lb cylinder head at 90* through every single hole. I have the second largest Harbor Freight standing drill press and broke through one of the outer head bolt holes on my heads because it wasn't square. No worries on the rest of the machining. At least have them cleaned, magnafluxed, and surfaced before installing.
I was just told the "5" heads were highly desirable and a good fit Correct, they are.
brownbomber77 is offline
Old October 22nd, 2019, 05:46 AM
  #43
Goodoldsreliable's Avatar
Alright, ive got them. The #5 heads are mine!
Now, they came with no valve springs, retainers, or anything besides 3 spark plugs and the valves lol. Can i use my factory springs or do i need to do some measuring and order something special?
Im waiting on head gaskets from rockauto that got retuned to sender and am thinking im just going to have to go to autozone and pay double to get them to me before next year..
Also, should i have it ported when i have it checked and the head bolt holes drilled out?
Goodoldsreliable is offline
Old October 22nd, 2019, 07:55 AM
  #44
And ive just read elsewhere that head gaskets are the same for all 69-76 olds so what do i need to order head gasket wise??
Old October 22nd, 2019, 09:03 AM
  #45
rktpwrdc10's Avatar
You need to order head gaskets for the 1977-80 oldsmobile 350. The 1969-76 head gaskets won't work on your block.
Old October 23rd, 2019, 05:24 PM
  #46
Out of Line, Everytime😉
olds 307 and 403's Avatar
I know the number 5 heads use regular retainers and your 3A heads use rotator retainers. You may be able to use them but it will depend on the spring pocket height on both heads. The Edelbrock Performer Plus springs are affordable but require non rotator spring retainers.
olds 307 and 403 is offline
Old October 24th, 2019, 05:23 AM
  #47
I’m pretty sure I have a set of retainers at the house that use the factory locks...I’ll check later. They fit in a flat rate envelope...
Old October 24th, 2019, 06:34 AM
  #48
rktpwrdc10's Avatar
I have factory springs and retainers on some j heads in my shed. I could part with if you end up needing them let me know.
Old October 27th, 2019, 08:08 AM
  #49
Thanks guys ill definitely let you know, ive got them at the machine shop currently and they should be done early this week!
Old October 27th, 2019, 08:55 AM
  #50
Sugar Bear's Avatar
If you are planning to install the springs and seals yourself go for it; but, no matter who assembles them be sure to vacuum test/seal check the final valve job before putting the heads on the block. This is literally a five minute procedure at a machine shop that cannot be done unless the heads are assembled, it confirms that the newly done seat grinding and valve grinding make a proper seal. Ask them to show you how it is done to learn.
Good luck!!!
Sugar Bear is online now
Old October 30th, 2019, 01:00 PM
  #51
What price range should i he looking for? I was expecting around $100 to have them cleaned and resurfaced, then a tad bit more for the drilling out of the head bolt holes. This guy just said itllbe around $420 to get them ready to bolt on. Should i grab my heads and run??
Old October 31st, 2019, 06:33 AM
  #52
No it's not a parts car!!
Schne442's Avatar
I just had my 7a heads for my 72 350 done, cost me $390.00 to have them cleaned, Magnafluxed, 3 angle Valve job and .25 Milled for the thicker .42 Felpro Gaskets
new Valves and springs installed. If they are doing all of that and also drilling for larger head bolts, $420 sounds reasonable.
Schne442 is offline
Old November 29th, 2019, 07:17 PM
  #53
Guys.... ive got two words for you....
SPUN BEARING!
Oh God, why.......
So what now? Is this thing laughing at me or what?
Old November 30th, 2019, 04:34 PM
  #54
Rod or main? Strip it down and get the crank turned or find a pre 77 Olds 350 block or motor. If the rods spun, they need resized by a machine shop. The 77 and up has a windowed, weaker block.
Old April 27th, 2020, 09:07 AM
  #55
Now that weather is warming up im doing some thinking. Will any pre 77 350 and its trans work here? No other major adaptions should have to be made, correct?
im going back and forth on whether it even matters to get a 76 or earler engine since i just planon having it as a daily/cruiser. I don't want to just abandon this engine because its "weaker".
Old April 29th, 2020, 05:54 AM
  #56
Any 68 to 80 Olds 350 will work. Even a 330 would bolt in place if in good running shape. The 73 to 76 motors seem to be easiest to find in good running shape. A 77 to 80 motor will work and worth less money. Just make sure it isn't a 260, a pre 85 307 would also work. The 85 and later 307's have tiny ports and a dog reputation. The transmission depends, just leave your current one in there. Get an estimate to rebuild your current motor and go from there. Good luck.
512Lac
October 27th, 2019 09:56 AM
simonb.
July 13th, 2014 04:27 AM
Jrod
January 4th, 2013 09:18 AM
WEBBISH
November 25th, 2008 12:28 PM
deltathunder
July 21st, 2008 08:10 PM
Quick Reply: HELP! Top End Rebuild 78 Olds 350
