Help with roller rockers
1968 Rocket 350 engine. Motor has been rebuilt with a mild cam. Everything has been replaced except the rockers. Wouldn't you know it a rocker broke in half while breaking in the cam the other day. I want to replace them all with some roller tip stamp steel rockers. I found some online but they said they were 3/8 and the bolt that holds the stock rockers in place are 5/16. I am assuming I will need studs instead of the stock bolts. Will I also need plate guides? Is there a kit to adapt to a stock head without having to drill bigger for studs? Any help is greatly appreciated. I'm looking for the least expensive roller rockers I can get. Thanks in advance........Todd
Least expensive isn't always the best... kinda like women.
You'll need a 5/16 X 3/8 stud... Comp and others make them. You may not see them in a catalog so ask... You engine shop can get 'em, too.
Comp and Elgin make a heavy duty non-roller tip rocker. I really don't see any advantge to using roller tips in a stock engine even with a mild cam. You'll never spin that rascal high enough to see any HP benefit IMHO.
You can use most any 1.6 rocker... some guys use the SBF style with good luck. Guide plates will be required. You MAY need to install higher clearance valve covers if you use a long poly lock.
Stay away from Chinisium parts or you may be buying them again...
The advantage of roller tip rockers as told to me by an engine builder a few years back is that they tend to give a closer to spec 1.5 or 1.6 than a stamped rocker which usually delivers less than 1.5 in actual usage.
You may want to inform your engine builder of that as well.
JRubino
December 30th, 2013 10:16 AM
