help car won't start
Ok, Went to pick my car up today and it won't start, It turns over, has fuel & spark. Car is a 1969 olds cutlass convertable, 350 engine with a 2-barrel Carb. car will start and rund only 4 a few seconds. soon as I press the gas it dies. if I give the pedal a couple hard pats before I turn the key...Car acts as if it wants to start but seems as though there is not fuel being delivered constantly. I disconnected the fuel line from the carb and stuck it in a bottle, turned the key , bottled filled with gas. used a spark plug tester car is getting a good spark.
would a bad choke cause the car not to start? I drove it with the bad choke for about 20 miles before
please help my baby sits clean and helpless @ the moment.
This may sound crazy but I don"t remember if we had a full tune up on this car. we did a new fuel pump, not filter. I did try to remove the little filter @ the carb housing inlet line. Ran the line without the filter....still no luck! Plenty of gas flowed into a bottle when i took the line off.
thanks for the reply's ended up needed a carburetor. It was not getting gas through it and leaking out the front side somewhere,
I bought an eldebrok 4 barrel intake I'm going to swap now with a 4 barrel carter carb.
regards
I have no clue what you're talking about, please excuse my lack of knowledge on this subject.
I did try to swap the intake however so many things needs pluged or changed before I can get the car running again.
Would it be better to swap to 4-barrel intake or rebuild the stock 2-barrel carb?
Did the starting problem occur after or before the intake swap?
Regards Stanley
problem started before anything was swapped, I haven't swapped anything yet still getting the parts togther. Fuel was not getting to the carb, something inside were the little round fuel filter goes on the front of the carb was leaking in that housing.
Regards Stanley
rodrieguz- Do yourself a big favor and install an in-line gas filter, preferably a clear one if you can locate one. This way, the major part of the dirt and junk will stay in the in-line filter and reduce the amount that the in-carb. filter will have to handle. The in-line type filter is much easier to service, with only hose clamps and flex. tubing to deal with. The fewer times you have to remove the hex-housing of the in-carb. filter, the less risk you run of leaks, cross-threading, etc. Good luck & Happy Motoring!!! Jim
I will install the inline filter. I pulled the intake tonight and there was a lot of gunk residue around a few of the rods. I cleaned everything up and vacuumed everything as I went along.
Would it hurt to spray carb cleaner on everything just to clean it up a bit more?
When I put the RTV sealant on the front and rear of the intake should I let it sit for a few before I put the intake down?
Thanks Rod
Thanks Rod
Follow the directions on the RTV tube. It will tell you what the manufacturer recommends for the best results. However, most RTV products allow you to mate the two parts together right away. Just make sure the two surfaces are clean, dry and smooth before applying the RTV, and wait the recommended curing time before running fuel through to the carb.. Keep us posted on your progress! Take care & Happy Motoring!!! Jim
Man guys I'm banging my head on the wall. Got the car back together, and it still won't start. Now it just rotates without even trying to start. We are getting gas to the carb.
I did change the distributor cap & rotor...we are getting spark.
What gives I'm clueless to the problem. any suggestions?
how are you checking for spark? if you fouled one or three plugs you may get spark on a new plug or a used plug or a screw driver to the ground trick but if your plugs are bad it is for not? Hope that made sense pull plugs and look at them
Stanley
Check the distributer shaft for wobble. Your points may be staying closed due to an eccentric distributer shaft. This happened to me years ago. The only answer for this type of issue is to replace the distributer. If that's the case, you may want to consider HEI (that's if you haven't swapped out already). Jim
