Heater hose
Old Jun 28, 2021 | 06:36 PM
denf221's Avatar
Heater hose
Looking to bypass heater core on my 72 supreme, any tips on removing the hose from the back of the manifold? Also would it just be easier to connect the hose from front if motor to hose connected to back of manifold? Is there a connector for that?
Old Jun 28, 2021 | 06:47 PM
Yes, it's OK to connect the hose from the water pump to the heater valve (or hose nipple) on the rear of the manifold. The two hoses are different diameters (5/8 and 3/4), but it can be done. I don't know if there's a reducer for that but your local auto parts or hardware store may have something.
edit:
AutoZone has what you need:
Dorman - HELP 5/8in X 3/4in Plastic Heater Hose Connector
https://www.autozone.com/fittings-an...E&gclsrc=aw.ds
Old Jun 28, 2021 | 07:39 PM
Factory heater delete cars just used a pipe plug in the intake and a cap on the water pump barb. You don't need a hose there, in fact that hose allows coolant to bypass the head instead of cooling it.
Old Jun 28, 2021 | 08:18 PM
denf221's Avatar
Old Jun 29, 2021 | 10:55 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
I've seen a tap inline with the hose, during the summer turn it off, and when its starts to get cold turn it back on.
airborne1942
May 29, 2017 08:22 AM
68442
Aug 10, 2016 03:50 PM
1yesfan
Oct 7, 2014 06:43 AM
defiant1
Jun 17, 2013 09:36 AM
my71olds
Apr 28, 2013 06:08 PM
