Headers
Old Dec 17, 2021 | 03:18 PM
Oldslvr76's Avatar
Headers
I have a 64 Cutlass with the Olds 403 small block and a Muncie 4spd in it. What headers can I run in this car? Will small block headers for a 68-72 work? Thank you.
Old Dec 21, 2021 | 03:13 AM
dragline's Avatar
Thornton has shorty style, out of stock right now. I'd call about your application first.
https://www.thorntonmusclecars.com/p...***-350-engine
Old Dec 21, 2021 | 06:53 AM
If you want real headers for performance (as opposed to shorty headers for appearance), ARH is the best bet. There's a reason why they cost so much more. The frame on the 64-67 cars is slightly narrower in the engine bay. Headers for these cars were common years ago, but today the manufacturers really only support the 68-up cars. Every header manufacturer routes tubes differently, and one vendor's 68-77 headers may fit an early car better than another's. Unfortunately there's no good way to know.
Old Dec 21, 2021 | 10:55 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
Holy smokes Joe, 1500 US for the headers.
Old Dec 21, 2021 | 11:48 AM
therobski's Avatar
Joe would extrude honing the exhaust manifolds gain any HP?
Old Dec 21, 2021 | 01:06 PM
If you start with W/Z manifolds, yes. The W/Z castings have individual runners. Unfortunately they won't work on the OP's 403, and despite what vendors may say, the aftermarket SBO manifolds are NOT W/Z type. They do not have the individual runners.
Old Dec 21, 2021 | 03:04 PM
ELY442's Avatar
Its a good thing the OP car is not a "supreme". It will not fit
Old Dec 21, 2021 | 03:45 PM
The really ludicrous part of that is that Summit has a footnote on they G-body trans crossmembers that they will not fit Supremes!
Talk about common sense being uncommon.
Old Dec 22, 2021 | 08:02 AM
Dynoking's Avatar
How are these headers for ground clearance? Overall fussiness/maintenance?
Old Dec 22, 2021 | 11:55 AM
Pretty much the same as for any headers. Yes, they will hang lower than manifolds. Yes, eventually the gaskets will leak and require replacement. Yes, you will probably have to move the combo valve.
Old Dec 22, 2021 | 02:43 PM
Dynoking's Avatar
Thanks!
olds70supreme
Apr 14, 2021 05:52 PM
Gianni71Cutlass
Jun 14, 2016 08:09 AM
brownbomber77
Mar 1, 2015 06:59 AM
cycomiko
Sep 3, 2010 03:31 AM
dar83501
Nov 20, 2007 11:45 PM
