Head ID??
Head ID??
Hello, I need help!! I've Identifiied the engine as a 1968 350. The heads, I don't have a clue. On the front outside corner is casting # A2. On the front left bottom is a large 8. On the center, between the exhaust outlets, is #411 929. Rear outside is stamped 272.
Can anybody shed some light for me?
OK, what I have is a 49 "88" coupe. It is a streetrod. When I bought the car, it was a 10 foot car. any closer you started to see the flaws. I'm now rebuilding the car. The party I purchsed the car from had made the remark, they put different heads on motor and couldn't get it to run. I made it run, but not to it's potential.
So bottom line I have a 68 block with "smog heads" and it can't breathe correctly?
When I get the car done, spring, I'll be more than happy to post pic's..
I believe that means it is a 1976 engine, at least it was originally in a 1976 vehicle.
I think your first 6 should really be a 3 though...
This number should take the form of "35Mxxxxxx" where:
3 = Oldsmobile division.
5 = year of manufacture (8=68, 9=69, 0=70, ..., 4=74, 5=75, 6=76, etc.).
M = location of manufacture (M = Lansing, B=Baltimore, X = Kansas City, Z = Fremont, CA, etc).
xxxxxx = last six digits of VIN of car that motor originally came in (original car's sequential production number).
Duane
Duane
I concur. It looks to be a 76 block and heads. That's not entirely a bad thing as the block is a solid foundation to start with and the heads can be worked if you don't have the cash to find different ones.
COOL. I tried to take a picture of the number, didn't work even spraying white and wiping clean. Did make it more ledgable. With the #'s that came up, to compare,
66M159315 is what I read or the first two #'s could be 33M159315, or 36M159315. The first two #'s aren't that clear.
Yep. 14cc dish piston with the large chamber yields a compression ratio of 7.8 to 1 +/- Not necessarily "smog heads" but ones with a large chamber. They need a little work, as do all the stock heads. Bolt on some early 350 heads and Cr bumps up to mid-high 8.xx to 1.
