Head gasket question
I've finished building the short block for my SBO stroker engine and have started working on to the top end. I'm using some ProComp aluminum heads and I noticed that one of the water jacket holes in the head gasket doesn't have a corresponding hole drilled in the block. There is a cooling passage hole in the head, but not in the block. Is this a problem? Should I drill a hole in the block to match the head gasket?
No hole in the block.
Should I drill a hole in the block to match the gasket?
The head has a cooling passage hole to match the gasket.
I am pretty sure there are always a few cooling ports that don't line up. I might throw the Corteco head gaskets on my 403 block to see how it lines up. Unless someone more knowledgable chimes in leave it alone.
Thanks for the confirmation. I had a set of '72 7a heads in the garage and they had the same "extra" hole as the ProComps. I did some web surfing and found lots of pics of Olds blocks in various states of rebuild; none of them had this hole drilled in the block. So I decided to leave well-enough-alone and started assembling last night. I'll post up some pics in my engine build thread.
https://classicoldsmobile.com/forums...ck-advice.html
jensenracing77
August 11th, 2015 06:49 PM
