head gasket issue 330 heads on 350... ?
Old Dec 18, 2016 | 05:36 AM
STLCRZY's Avatar
Guys can it be that the wrong head gasket is the reason for a water leak on on passenger site between the head and block.
We notice it on the engine stand.
Heads are 4# 330
Block 350 68-70
Kit we use
https://m.summitracing.com/parts/slp-260-1022
Old Dec 18, 2016 | 05:55 AM
Gaskets are the same. Did you torque the bolts properly in the correct sequence.
Old Dec 18, 2016 | 06:59 AM
STLCRZY's Avatar
Yes
Old Dec 18, 2016 | 08:02 AM
lemoldsnut's Avatar
Did you have the heads and block check for straightness? and were you very clean about how you put it together and prepared the surfaces?
They take the same gaskets. Should fit perfectly. 4 heads are in my opinion a great head that is way overlooked when it comes to Olds Small blocks.
Old Dec 18, 2016 | 08:14 AM
STLCRZY's Avatar
Problem solved.
Old Dec 18, 2016 | 09:42 AM
Originally Posted by STLCRZY
Problem solved.
Care to elaborate?
Old Dec 18, 2016 | 10:29 AM
care to elaborate?
x2
Old Dec 31, 2016 | 09:39 AM
STLCRZY's Avatar
Not property torqued bolts - dead torque wrench
thanks guys
Old Dec 31, 2016 | 02:36 PM
Glad all worked out.
Rilmar
Jul 20, 2021 08:10 AM
85Cutty442
Jan 28, 2016 11:53 AM
ihengineer76
May 10, 2013 10:01 AM
aussiemobile
Feb 15, 2013 07:31 AM
a64olz
Jul 3, 2012 06:32 AM
