Head bolt sensor
Old Mar 14, 2013 | 03:17 PM
Oldwolf's Avatar
Question Head bolt sensor
Can you help me and explain if this bolt and sensor is Olds parts? I found it in a box with engine fasteners for a olds 350. Is it Diesel stuff?
Old Mar 14, 2013 | 06:41 PM
Lady72nRob71's Avatar
Wow - never seen such a beast!
Knock sensor??
Old Mar 14, 2013 | 06:44 PM
Sure looks like it could be a knock sensor.
Definitely not original.
I had an '80s-vintage knock sensor / timing retarder on my '68 back in the '90s. It didn't work.
Octania's Avatar
~1968 Toronado Hot Engine sensor
Old Mar 14, 2013 | 06:46 PM
Really? So it's OEM?
I've never seen one.
Water temperature sensor wasn't good enough for them?
Old Mar 14, 2013 | 06:51 PM
So it's this thing, I take it?
Do you know what their rationale was for using this?
Old Mar 14, 2013 | 08:33 PM
rocketraider's Avatar
Oldsdruid
Yes. 68-70 actually.
Toronado developed a reputation early on for very high underhood temperatures as the low hoodline restricted airflow and heat dissipation considerably. That's why it is important on an early Toro to keep all the radiator seals, shrouding, and air dams in place- so airflow goes THRU the radiator instead of around it.
The 66-67 cars had temperature gages; 68-70 used a pair of warning lights for engine temp. The sender on the intake triggered the normal red HOT light, the one in the head bolt (LH head, in the bolt directly above the trans dipstick) triggered a flashing yellow STOP ENGINE warning.
Old Mar 14, 2013 | 10:12 PM
orange442's Avatar
All the 350 diesel motors I just tore down had one of those. I had read a post previously about a guy tearing a DX apart and he could not get the head off one side. He talked to engine guys and all the other guys that posted were saying to check head bolts but he said he had checked many times but they were all out. He finally saw the bolt under the sensor and was very embarrassed to say the least.
Old Mar 14, 2013 | 10:27 PM
Oldwolf's Avatar
OK! Thank you all for the fast answer. Good information, maybe i can use it for a warning light. Toronado seems right for me, i have the tilted oilfilter housing in the box as well.
Stanley
schapman33
Aurora
Dec 8, 2008 07:49 AM
jaco
Jan 5, 2007 08:57 PM
bearls
Dec 17, 2006 06:37 PM
beebee007
Aurora
Aug 17, 2006 06:45 PM
DonFrost
Ninety-Eight
Jul 12, 2006 03:58 AM
