Having trouble with intake...
Old Jan 16, 2009 | 09:53 PM
csouth's Avatar
Question Having trouble with intake...
I havent posted in a while, but I need some help. I installed a new Edelbrock Performer RPM. I'm having a problem finding the right size heater hose fitting. The one closest to the brake booster is 3/8. The passenger side is not 1/2 and 5/8 could take a thread. I dont want to cross thread anything. I know I could alwyas run the hose to the drivers side, but I still need to know the size if I were to block it off. Can anyone offer some insight?
Old Jan 16, 2009 | 11:43 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Cut the head off of your old heater control valve and run your heater core line to that pipe.
If you want to block it off, just pinch the pipe closed and weld it shut.
Saves a trip to the hardware store.
Old Jan 17, 2009 | 09:12 AM
That's supposed to be pipe thread, which are tapered. If the threads weren't tapped deeply enough, that could be the problem.
Old Jan 17, 2009 | 02:30 PM
csouth's Avatar
Joe,
Do you think i should run a 5/8 thread chaser through it? I'm trying not to ruin a brand new intake, ya know...
Old Jan 17, 2009 | 02:35 PM
Joe,
I would run a PIPE thread tap through it. I assume that's what you mean. A standard 5/8" straight thread tap is not correct.
Old Jan 17, 2009 | 04:32 PM
citcapp's Avatar
Make sure you are trying a 5/8" pipe thread fitting and not a fine thread fitting, that could be your problem. You can find brass pipe thread fittings at the plumbing or hardware stores at least around here you can no problem. Good luck
Old Jan 18, 2009 | 09:16 PM
csouth's Avatar
I'm going to give Edelbrock a call on Monday. I measured the diameter and it looks like 15/16th's.
Old Jan 19, 2009 | 10:11 AM
Well, the tap drill size for 3/4-14 NPT thread is 29/32", so that sounds about right.
Old Jan 19, 2009 | 10:14 AM
NPT thread dimensions
This link might be helpful:
http://www.plumbingsupply.com/pipethreadsizing.html
Old Jan 19, 2009 | 12:07 PM
csouth's Avatar
Joe
I talked to Edelbrock and was told 3/4 NPT. I picked up a fitting and will try when I get home this evening. Thanks for the link the chart BTW. I'll let you know how it goes...
Old Jan 19, 2009 | 12:57 PM
gearheads78's Avatar
car guy
As Joe says pipe thread is not like std threads. I 3/4 bolt will fall through a hole for 3/4 pipe.
Old Jan 19, 2009 | 01:33 PM
csouth's Avatar
Gothcha. I went to NAPA during my lunch break. The fitting I picked up was 3/4 NPT as stated by Edelbrock. I'm hoping this works.
Old Jan 19, 2009 | 05:29 PM
csouth's Avatar
Seems like it is 3/4 NPT. I tried a bushing and was going to add a 1/2 heater hose fitting, but I don't like the look. I'm just going to order the correct part. Thanks for all your input guys...
Marks76442
Mar 19, 2014 11:01 AM
jackedolds
Nov 9, 2011 08:05 AM
misercola
18
May 3, 2010 03:39 AM
Nako29
Jan 26, 2010 09:38 AM
kimberlies7
Aug 28, 2009 03:03 PM
