Harrison 4 Core Tag
Going from memory on this. IF CP 74 are the codes that make up the EB radiator. IF is the drivers side tank, CP is the passenger side tank. 74 is the trans cooler in the passenger side tank. The tank codes (IF CP) will be embossed in the tank. There is also a date code embossed in the passenger tank. The date codes are letters, A Jan, B Feb...I is not used. It is located between the C and F. The font of the date code is about half the size of the tank code. Hope this answers your questions, if not let me know.
Don W
Don W
Heres one that I sold. Yours should have the same codes stamped into the tanks.
SOLD 1970 Cutlass/442 4 row radiator EC code, CI IF on tanks, A assembly SOLD - ClassicOldsmobile.com
