Harmonic Dampner installed correctly?
I put my new Scat/Powerforce dampner on the other night using an installation tool and a crescent wrench. Unfortunately I broke the tool off in the snout during the process, but luckily it easily came out of the snout. I then put the new ARP bolt on with their lube and tightened it to 200 ft/lb per ARP's installation sheet. Does this look like it's on far enough? (not the first time I've asked this today)
Throw some oil in her and tilt the front of the motor down on the lift and spin it by hand a few time. You should be able to see if its leaking from the seal then. Good ideal on seeing if the belts will line up as well.
I would mock it up but some of the accessories are still hooked up in the engine bay. I did look at pics of the stock dampner and found the wear line is in roughly the same spot as where the new seal sits on the new dampner, so I think it's okay. Might try the tilting forward bit though just to see, thanks!
Oldssupreme
Drivetrain/Differentials
31
April 21st, 2024 02:14 PM
junior supercar
December 2nd, 2014 08:04 PM
oldzy
Suspension & Handling
January 25th, 2011 09:07 PM
