Good Replacement Intake Manifold
Old Oct 3, 2012 | 08:42 AM
carlstretch's Avatar
I have a '71 Cutlass Supreme Convertible with stock 350 and intake manifold. I have replaced the carb from the Quadrajet to a Holley 600. I had to use an adapter to go from spread to square bore. I am eventually going to pull the engine out this winter to clean/paint it. I would like to put on a new intake manifold while I have it out.
Any suggestions? It's just a cruiser and while increased performance is always nice, but not the focus. I have been looking at the Edelbrock 2701, 2101 and the RPM 7501.
Thanks in advance for the advice.
Old Oct 3, 2012 | 10:08 AM
captjim's Avatar
The Performer is going to be the best choice, but is not going to make a ton of difference. Still, it is lighter, looks better, and IMO is a bit better than stock. Used ones are plentiful for around $100.
Old Oct 3, 2012 | 10:30 AM
x2
Old Oct 3, 2012 | 12:51 PM
Suggestions? Yeah. The Qjet is a MUCH better street carb.
Old Oct 3, 2012 | 01:04 PM
DeltaPace77's Avatar
No doubt about it, stick with the Q-Jet. If the carb is old and worn out, definitely worth fixing.
Old Oct 3, 2012 | 04:44 PM
I agree that the Qjet is the preferred carb,.. but,.. My brother in law restores old cars and knows Holley's inside and out. (meaning,.. I can work on/adjust a Holley for free) We tried to fix the Qjet and the damn needle valve, spring and float assembly gave us problems, even after replacing them. So for now, I want to keep using the Holley. I will eventually send the Qjet out to get rebuilt by someone who knows what they are doing.
Ok, back on topic,... I'm thinking the Edelbrock performer that accepts square and spread bore carbs will be the right choice for me. Yes, eventually I will put a Qjet back in but for now, the Holley is staying.
Thanks,
Old Jan 15, 2015 | 09:33 PM
pwall2's Avatar
tell me about the air gap intakes over the performer Edelbrock is it worth the money for a gain in performance,i wait ..
Old Jan 16, 2015 | 09:01 AM
This thread is 2.5 years old. You likely will have better luck if you start a new thread with your question.
shamusj
Dec 18, 2014 09:28 AM
Alex72cutty
Apr 21, 2014 01:34 PM
svnt442
Jul 17, 2011 04:43 PM
hobs
Jun 5, 2011 11:23 AM
Steve Wike
Feb 1, 2010 07:00 AM
