Gold Rocket 350 vs. Blue
Old December 20th, 2012 | 11:06 PM
blunce's Avatar
Always thought most (or all) Rocket 350's were gold. Have recently seen some that are blue, including the one I dropped in my car ('69). So can anyone enlighten me as to why some are gold and some are blue?
Thanks!
Old December 20th, 2012 | 11:19 PM
They changed to corporate blue in 1975 I believe, before that they were gold.
Old December 20th, 2012 | 11:47 PM
blunce's Avatar
Hmm, would a post '75 motor still have 5 heads on it?
Old December 21st, 2012 | 02:08 AM
DoubleV's Avatar
No. 5 heads were for 68-69 350's only.
Old December 21st, 2012 | 03:38 AM
blunce's Avatar
Maybe I've got some kind of franken-motor then. It's got 5 heads, but blue valve covers and oil pan. Not sure about the block or heads and the intake has a nice rusty patina to it.
Doesn't really matter too much as it's essentially a back up motor. I've got another one disassembled awaiting a full rebuild someday and that one is a '69 motor.
Was really just wondering why there were blue motors. Now I know! Thanks!
Old December 21st, 2012 | 05:03 AM
Seff's Avatar
The progression was small chambers and slightly dished pistons for high compression (x-70), then heavily dished pistons and small chambers for low compression (70-72), ending with slightly dished pistons and big chambers (73+). That you have a late motor with early heads means you have good compression.
Info according to the Olds faq.
Old December 21st, 2012 | 08:14 AM
oddball's Avatar
Someone could have just repainted it.
I vastly prefer the 455 blue to the 350 gold, so I paint all my engines blue. It's purdy.
Old December 21st, 2012 | 01:05 PM
krooser's Avatar
Hot Rod Has Been
Gold is much more valuable than blue... what the spot price of blue vs. gold? Go with gold... it will be worth more when you sell it!
Old December 21st, 2012 | 02:15 PM
blunce's Avatar
Not sure if you're making a joke relating to actual Gold, but if not, I really just wanted to know what the deal was with blue engines. The motor I dropped in my car for a "in the meantime" motor, is either all blue or has been fitted with blue valve covers and oil pan.
When I build the actual motor that will reside in the car for the rest of it's life, it will be either Olds Gold or something that compliments the eventual body color, though I think it'll probably be gold.
Old December 21st, 2012 | 02:19 PM
krooser's Avatar
Hot Rod Has Been
Blue engine came later... early 70's maybe? Someone knows the real year..
Old December 21st, 2012 | 04:57 PM
Redog's Avatar
Gold=Leaded fuel
Blue=Unleaded fuel
Old December 21st, 2012 | 07:07 PM
captjim's Avatar
Someone could have just snagged the tins from a mid 70s car. Also, I like the 60's bronze color, very cool, IMO.
Old December 21st, 2012 | 07:29 PM
Originally Posted by Redog
Gold=Leaded fuel
Blue=Unleaded fuel
Not exactly.
'72 and '73 were both unleaded motors, and they both had gold 350s (I think the first year for blue was '75).
Old December 21st, 2012 | 07:42 PM
Redog's Avatar
I forgot to mention I HATE the term "gold" rocket or "Blue" rocket
It's just some ghetto term, that's it
Old December 21st, 2012 | 09:38 PM
krooser's Avatar
Hot Rod Has Been
I never like putting the word "engine" and "blew" in the same sentence...
Old December 21st, 2012 | 11:01 PM
blunce's Avatar
more eggnog fellas?
Old December 23rd, 2012 | 09:15 AM
turbobill's Avatar
Where is the best place to find the head CC/piston dish specs for the various combinations?
Old December 23rd, 2012 | 09:26 AM
MXman112's Avatar
Tons of info
http://www.442.com/oldsfaq/oldsfaq.htm
Old December 23rd, 2012 | 09:30 AM
rocketraider's Avatar
Oldsdruid
1975-77 engines were metallic turquoise blue, but they were not GM corporate blue. That nonsense came later, when they were smarting from the Olds with Chevy engine fiasco and were trying to engender a "corporate" engine identity to stave off more legal action.
Far as I'm concerned they were trying to turn B-O-P-Cad into a pushmi-pullyu or a hermaphrodite.
Old December 23rd, 2012 | 09:35 AM
Don't forget that those FAQs are not flawless, and that the nominal combustion chamber volume is usually a bit less than the actual measured volume.
Old December 23rd, 2012 | 06:34 PM
Seff's Avatar
^ Is correct. For example, the 64 cc heads are closer to 68-70 cc measured.
Old December 23rd, 2012 | 11:05 PM
blunce's Avatar
Well, I don't know what motor is in there. It does indeed have 5 heads, and blue everything else though it's really faded, worn, and covered in dirt/grime/grease accumulation. So, since it does have the 5 heads, I guess it could be a repainted '68-69 motor, or a post '75 motor with 5 heads painted blue to match and thrown on there.
Isn't there a number punched into a flat spot on the block somewhere to identify the block at least? Again, it doesn't really matter what it actually is, I'm really just curious is all.
Old December 23rd, 2012 | 11:38 PM
https://classicoldsmobile.com/forums...g-numbers.html
Old December 24th, 2012 | 12:49 AM
64Rocket's Avatar
What is the very first number on the oil fill tube.
If it by chance it is the original fill tube for the engine, the first number will tell you the year of the engine.
Gene
Old December 24th, 2012 | 02:51 AM
blunce's Avatar
Gene
That would be a 9. So apparently at some point, someone decided they didn't care much for a gold engine and painted it some kind of blue. Was also starting to see a few spots where the old gold was showing through the chipped blue paint.
Mystery solved.
Oh, and I think I remember the number behind the water pump being 395558 2
Old December 24th, 2012 | 07:03 AM
Gold is much faster, lol! What probably happened is the blue was the only paint laying around the garage that day.
Old December 24th, 2012 | 08:24 AM
Oldsdruid
That or it's a jobber rebuild engine and that's the color that particular jobber painted their engines.
Look on the machined pad at left front side of the block. The VIN of the car it was originally installed in should be on that pad. 2nd number will tell you what year engine.
Old December 24th, 2012 | 12:32 PM
jslabotsky's Avatar
Telecom Guru
I concur that it's more than likely been rebuilt and corporate blue was all they had available. You can buy the corporate blue in any parts store, but the correct Olds colors are not.
Old December 24th, 2012 | 12:38 PM
krooser's Avatar
Hot Rod Has Been
Even a Rolls is better in gold...
http://popcultureblog.dallasnews.com...R5_3156507.jpg
Old December 24th, 2012 | 01:15 PM
M-14's Avatar
When I see a blue olds small block I say to myself 'windowed mains, low,low compression, lame cam.' They're hard to see under all that emissions crap anyways.
theoldsrocket
Paint
February 4th, 2011 03:52 PM
cutlassKing
November 29th, 2010 04:05 PM
RAMBOW
March 14th, 2010 08:44 AM
cutlassKing
April 13th, 2007 02:50 PM
NSolds
February 6th, 2007 05:39 PM
