Gas in brake booster??
Old Jul 19, 2018 | 04:22 PM
rodan's Avatar
Hi guys , having a problem that I can't figure out. 69 cutlass with 350 running a Holley 770 cam carb. Brake booster Vacuume port is on the back of the carb and I'm getting gasoline into the booster! Can anyone explain?
Frustrated
Old Jul 19, 2018 | 07:01 PM
You have an issue with your carb. There should only be vacuum on that port, I'm assuming the fuel vapors are getting into the booster when the engine is turned off.
Old Jul 19, 2018 | 07:29 PM
Actually, any vacuum comes from the intake manifold, where there is fuel. Reversion (pulsing of the intake charge in the runners due to valves opening and closing) causes the fuel/air mixture to move back and forth in all the lines connected to the intake manifold. The most likely cause is that the check valve at the booster vacuum inlet is bad. This check valve is supposed to prevent any flow into the booster.
7898regency
Brakes/Hydraulic Systems
Apr 15, 2019 06:45 PM
Corswiki
Apr 10, 2019 07:29 PM
zodiacblueS
44
Oct 12, 2014 03:22 PM
63super88
Mar 18, 2014 02:03 PM
Tangovino
Feb 5, 2009 11:00 PM
